I think nV are smart enough to know that a 3GB 1060 has *no* chance of selling.
A 3GB 1050 @ $149 is a different story.
ye 6gb is good for 1080p
3gb not so much now
The GTX760 launched at $250.
For the 2GB version...
Standard 660 had 192 bit bus and there were even 256 bit versions.GTX 660 Ti was probably the last relatively good x60 part. Certainly the last one to have better than 128 bit bus.
The GTX 460 256bit version did the job before that.
760 and 960 were both a bit underwhelming.
And?The gtx 760 was based off GK104, not GK106. It was a cut down salvaged gtx 770, not a full enabled gk106 part.
The very idea of a founders edition with literally zero benefit to it is such an insult.
Does it even say founders edition on the box? do you even get that?
I have used nvidia only since the 260 but they are really pushing it with this bs.
Those push up bras are wonderful things![]()
I don't think the 1060 will be able to equal a 980.
I am basing this on how the other Pascal cards perform against the Maxwell cards.
For example the best 1080s on the Heaven 4 bench score about 3300 and the best 980s score about 2100.
If you half the 1080 score as the 1060 is basically half a 1080 you get a score around 1650 which is a long way short of the 980s.
Just don't buy a FE card. I bought a Gigabyte G1 Gaming 1080 that was cheaper than the FE and comes with a decent cooler.
Just look at that PCB:
http://www.purepc.pl/files/Image/news/2016/07/gtx_1060_pcb_1.jpg
Room for a 256bit/8GB model it seems...
Have they really prevented people SLI'ing these cards?
It might not be the case here. The G1 gaming gtx1070 is £50 more expensive than the Founders Edition. I think pricing for the gtx1080 release was slightly better when comparing to the gtx1070. It could go either way.
First NVidia gimp high end users with only 2 way SLI on the GP104 cards.
Now they are really having a laugh limiting mid range cards to single card usage.
those coolers are not equal ^^'
...and the 2 gen later, 1060 still got the same low memory bandwidth as the 670 and 760, with a even smaller bus-sizeThe GTX760 launched at $250.
The funny thing about mGPU usage is you can use 4 mid range RX480s in Quadfire which are faster than 1080 SLI lol.
Perhaps it's more along the lines of neither company wanting a price war with increased costs on these smaller processes.
In other words, prices might still be higher than last gen even if both companies had their full ranges out, and the matched each other.
Can only hope that costs do come down in the longer term as things mature.
Wonder how long we'll be on 14/16nm.
