I went from an SV to a CBR600F and I think you will be suprised at just how much more speed you get by moving to an IL4 sports. Yes you have to get used to the fact there is not a lot going on below 5K revs in comparison but you soon get used to it.
By all means look and go for a 1000cc but just wanted to point out you don't have to go that high to get more performance and power than the SV
I'm with this man. When I stepped up from an SV to a ZX6R the difference was significant.
If you're commuting don't forget running costs will increase. Tyres, chain, sprockets etc are all bigger and cost more. It also won't be as good on fuel. For some idea, my ZX6R will do 150 miles on a tank on a stroll, on a 1000 you're looking at less.
) and £13 extra for chain and sprockets. Running a 1000 isn't really that much more costly than running a 400/600, apart from the extra tyre wear, but you'll probably save that on the front tyre wear
MT10s and S1000Rs aren't faired, aren't supersports, and I don't want that type of bike, so I don't know how relevant that is.
It's relevant in that the £8k asking price for that Honda seems a lot of money to spend on it. Ok, if that was the EXACT bike/version you wanted I can see it, but it's not is it? You seem quite open to ideas?
I just think 8 grand puts you in territory you may not have considered. A work colleague just bought a newer S1000RR for the same money you are looking at. It's a supersport, faired and absolutely loaded with toys.
I don't want to rain on your parade, but you've gone from 125 to a middle capacity SV, and now planning to jump in to the big capacity supersports in a small space of time.
Run some insurance quotes as that will need factoring into your budgets.
Of course if you're an old git like I am, the difference between a CBR600RR and a CRR1000RR insurance will be about the same a as packet of M&Ms.
For 8k I can think of a lot of nicer bikes than that CBR1000.
(But then I just really really don't like the look of them for some reason).
RSV4 and find a good independent nearby?
I'd hope he's done some insurance quotes, otherwise he might be in for a large shock! There's a reason I'm going for a naked 1000cc as my next bike, even 600cc sports bikes are £1200+ insurance, vs £300 for a naked litre bike.
) the cheapest is £1063 with a £600 excess.TL1000?
TL1000?
Are you really suggesting one of the most challenging litre bikes ever created as an everyday commuting tool?![]()
A lot of it's mythical window making reputation has been exagerated over the years. If the suspension has been properly sorted they are fine, but they are big heavy old things even though they go pretty well.
