The Pascal GTX 1070 Owners Thread
10 Oct 2012
Denmark
Who has the quietest fans?
I've went with MSI after trying to find out and couldn't find a whole lot of info, nobody else seems to know.
MSI is 100mm and dual ball bearing fans.
I don't know if anyone else uses bigger fans or a better type of bearing.
Doesn't seem like anyone goes full Noctua and uses an SSO bearing.
I just want silence and quality, and to stop having bad luck.
Had an EVGA 650 P2 fan fail after 15 days and my Gigabyte 1070 WindForce OC is being RMA'd because its fans grind and it can't even break 2000mhz core.
If my MSI Gaming 1070 8G has ridiculous coil whine or dysfunctional fans I'm going to have a mental breakdown, throw my PC out the window, change names move countries and start over with my life and PC.
No point in having all Noctua case fans if I keep getting broken loud garbage that is way louder than them.
Well i hope this can give you a bit of piece of mind but my MSI 1070 ARMOR OC which lets face it is using the cheapest non blower cooler they have are doing fine in temps(72c OCed to 2025), noise and has no coil whine. Also my sample breaks the 2ghz barrier.
6 Aug 2009
I've seen some good results from the Armor MSI cards around the internet. Tbh I don't think there is a lot in it, they'll all play games very well, I'm sure most of us wouldn't notice if we didn't know what was in the case.
28 Dec 2009
Wales
Palit Jetstream/GameRock/Gainward Golden Sample have super low spinning fans and can spin as low as 900-1100 rpm during gaming load with a chunky 2.5 slot cooler.
You still won't find much quieter than the Gaming X though, you will be lucky to hear it spinning and not likely to go over 1300rpm when gaming. Fingers crossed you don't get any coil whine, although I've never had that with MSI cards.
Ive gone for the palit for that reason. Fans turn off during normal use/low load for a quiet system. My EVGA 970 did that and it makes hell of a difference
Man of Honour
OP
21 May 2012
Dalek flagship
Welcome and on TROH.:)
The Roll of Honour.
Date 10/07/2016, Make Gainward Phoenix Golden Sample, roddypoddy, Link
Date 08/07/2016, Make Palit GameRock Premier Edition, JTrickle, Link
Date 08/07/2016, Make Zotac AMP Edition, gtw1212, Link
Date 07/07/2016, Make MSI Gaming X, magicoi, Link
Date 06/07/2016, Make MSI Aero OC Edition, Amatyr, Link
Date 06/07/2016, Make MSI Gaming X, divinebeetle, Link
Date 04/07/2016, Make MSI Gaming X, i_am_jon, Link
Date 04/07/2016, Make Palit GameRock Premier Edition, Phil87, Link
Date 03/07/2016, Make MSI Gaming X, V_R, Link
Date 03/07/2016, Make Palit GameRock Premier Edition, foxyfaefife, Link
Date 03/07/2016, Make MSI Armor OC Edition, chris-82, Link
Date 02/07/2016, Make Palit GameRock Premier Edition, razorpakk, Link
Date 02/07/2016, Make Palit GameRock Premier Edition, styuR, Link
Date 02/07/2016, Make MSI Armor OC Edition, Shawreyboy, Link
Date 02/07/2016, Make Gigabyte G1 Gaming, Gripen90, Link
Date 01/07/2016, Make Gainward Phoenix Golden Sample, shrek2, Link
Date 01/07/2016, Make NVidia Founders Edition, BornEvil, Link
Date 30/06/2016, Make Gainward Phoenix Golden Sample, thefogo, Link
Date 30/06/2016, Make MSI Gaming X, Carta, Link
Date 29/06/2016, Make Zotac AMP Edition, Charlatan, Link
Date 29/06/2016, Make MSI Gaming X, Daaaveee, Link
Date 29/06/2016, Make MSI Gaming X, Aretak, Link
Date 29/06/2016, Make Inno3D iChiLL X3 Edition, leerogers00, Link
Date 28/06/2016, Make MSI Gaming X, DougF1, Link
Date 28/06/2016, Make MSI Armor OC Edition, markoboyo11, Link
Date 27/06/2016, Make Zotac AMP Edition, Mangochutney, Link
Date 25/06/2016, Make MSI Armor OC Edition, BornEvil, Link
Date 23/06/2016, Make MSI Aero OC Edition, McGraw, Link
Date 22/06/2016, Make MSI Armor OC Edition, smithy83, Link
Date 21/06/2016, Make MSI Armor OC Edition, Phixsator, Link
Date 20/06/2016, Make Palit Founders Edition, Paul_cz, Link
Date 20/06/2016, Make NVidia Founders Edition, Dave2150, Link
Date 20/06/2016, Make MSI Gaming X, AthlonXP1800, Link
Date 20/06/2016, Make Gigabyte G1 Gaming, w00dy85, Link
Date 19/06/2016, Make MSI Gaming X, kully1972, Link
Date 18/06/2016, Make MSI Gaming X, AliGoz, Link
Date 17/06/2016, Make MSI Gaming X, philo-sofa, Link
Date 16/06/2016, Make Palit Founders Edition, Biffa, Link
Date 16/06/2016, Make EVGA Founders Edition, Daaaveee, Link
Date 14/06/2016, Make EVGA Founders Edition, mankycrack, Link
Date 13/06/2016, Make NVidia Founders Edition, !bluetonic!, Link
Date 12/06/2016, Make MSI Founders Edition, yoyo59, Link
Date 11/06/2016, Make MSI Founders Edition, JamesM, Link
To get on the Roll of Honour all you have to do is post a pic with your user name on it of your GTX 1070.​
27 Feb 2015
The Roll of Honour.
I am missing of the list :)
27 Mar 2006
Mine. Happy days.
[/URL][/IMG]
28 Dec 2009
Wales
Oh ok did it just come in a plain box then?
last time i bought OCUK value i got zotac and a friend got asus i just figured they put the value deals out there to control stock levels, probably wrong.
nvm thanks for replying :)
forgot to say you can check in gpu-z i think it should show card make in the "subvendor" box, if u have gpu-z installed that is no worries if not.
Yeah came in a plain white box with a driver disc. Packed it all away now though sorry bud.
ps the palit card is awesome
31 Oct 2002
I'm struggling to understand why anyone would have bought the Founders Edition. Would someone be kind enough to explain ?
Some prefer blower coolers, so that almost no heat is dumped into your case. It enables smaller form factor cases, plus requires less case fans.
Some also like the look of the founders edition (reference card). I quite like it, mostly all metal construction feels quality and the geforce lego is pretty nice.
2 Nov 2009
Brum
I'm not fooled by looks, that's why I chose a Palit Gamerock Premium.
Unless you really have to have a small PC, why would you pay more for a blower cooler, when you could buy a better card for less, and use the money saved for a larger case ?
17 Feb 2014
bedfordshire
I bought a 1070 founders to go in a tiny 250d case for a 4K HTPC for my living room, I wanted to put a nice zotac or msi in there but they just wont fit :confused:
when i tried my 1080 FE thats in my main rig with the reference blower before i put the water block on i thought it was easily the quietest refrence cooler i had heard yet not a problem at all.
no where near as loud as the old 7 and 9 series ref coolers they were bad but these new FE's are a big improvement and feel much better quality looks aside.... ;)
