Oh it probably only happens once every few days. It's probably down to me not pushing up enough.
Also, check the ball bits on the rod are lubed. Mine went dry on my Hornet once and caused all sorts of weird issues with shifting. If you lube it properly, it'll go in to gear easier (if it's currently dry). You can take the whole thing apart, give it a good clean and re-lube quite easily.
Also, check the ball bits on the rod are lubed. If you lube it properly, it'll go in to gear easier (if it's currently dry)..
Yeah it's not a small job, it's cylinder heads and cams out I think, a lot of that will be labour.
I think my local Aprilia place quoted around £350-£400 for a 'big' service which includes valve clearances on a Tuono.
