Ello all.
PC Specs:
CPU - Intel i7 3930k 3.2GHz Hex Core (Overclock is 4.4GHz)
Ram - 16GB Corsair Vengence Ram
OS HD - 120 Corsair SSD
Storage - 2 x 500GB Samsung Evo SSD
Storage - 2 x 3TB WD HHD
GPU - 2 x 4GB EVGA GTX 680 (SLI)
Coolage - Corsair H100 Water Cooled
PSU - Corsair AX1200 PSU (1200w)
SoundCard - Creative Soundblaster ZxR
So there seems to be 2 issues with the PC
1) The PC would randomly crash / restart regardless of gaming or desktop idling. This hasn't happened for a while though.
Little Background:
As of Now:
ATTEMPTED FIXES
No clue what this is related to as there is no error messages
However I have just done the following so will keep an eye out.
MEMTEST (Sticks Are Fine)
ALL BIOS, CHIPSET, LAN AND OTHER DRIVERS NOW UPTO DATE
2) The PC Would present me with Low Virtual Memory Messages when playing ARK:Survival Evolved or RUST.
However I went into ark and unchecked the following options;
High Quality Materials
Sub Surface Scattering
High Quality VFX
I had the game loaded and playing for a full day yesterday, I had a much better / consistent average 45 FPS and not a single low virtual memory issue.
Could one of these settings be causing my PC to suffer from low virtual memory?
Also I'm planning on upgrading to a 1080 TI If / When its released. By doing this would this prevent a Low Virtual memory issue as I feel my GPU's aren't quite up to poke to run ARK with decent settings.
However I wouldn't have thought the GPU would cause low virtual memory.
ATTEMPTED FIXES
AUTO VIRTUAL MEMORY ALLOCATION
INCREASING VIRTUAL MEMORY (16GB - 32GB - 64GB)
INSTALLING OS ON ANOTHER SSD
WINDOWS 7
WINDOWS 8.1
WINDOWS 10
ALL BIOS, CHIPSET, LAN AND OTHER DRIVERS UPTO DATE
Any help, Information, Idea's would be great.
Cheers.
			PC Specs:
Little Background:
4 Years ago I Bought the PC from another reputable retailer which built the PC of the parts I selected and applied an OverClock. For about a year and a half the Overclock worked fine, however it began to generate some BSODS (Windows 7) I disabled the OC (BIOS Profiles) and all was well.
I would put the OC back on from time to time but the issue persisted and I would return to default.
These crashes would happen in games, Game Dev Software (Unreal Engine 4) or even on the desktop Idling.
I Upgraded to Windows 10 a few months ago and tried the OC but the problem persisted.
With no OC The problem even caused my PC to restart with no error message When playing Project cars and Guild Wars 2 in quick succession of reloading and beginning to play the game.
Original theories of this was due to GPU overheating, however after monitoring GPU Temps they was sitting at around 80°c and didn't seem to cause a restart.
This led me to believe that it was the PSU issue as there was no BSOD or error message.
As of Now:
I recently began to have some issues with the PC with the OC Disabled. In games such as Guild Wars 2 I get 9-12 FPS at times (where I was once getting 30+), Development Software seems to slow right down also.
So Yesterday and today I began to run tests, I applied the OC again to try and see if there are any issues and behold there was.
Something is leading me to believe it might be a memory leak, however I'm not to clued up on this to confirm.
ATTEMPTED FIXES
High Quality VFX
ATTEMPTED FIXES
WINDOWS 7
WINDOWS 8.1
WINDOWS 10
Cheers.
