- 6 Jan 2013
- Rollergirl
No crashes or anything?
Rock solid.
Can anyone answer me this, i have like 60 games installed since building new pc last year, i have been using same graphics drivers, so there almost a year old, if i update to the very latest nvidia drivers, do i then have to redo all my games graphics settings in each game ? and in nvidia control panel will i also have to redo all that stuff, or is that saved ?, oh, im using a gtx780ti. Thx
The latest driver is making my games crash to desktop now and then (siege is one example) when i didnt get any crashes with the previous driver. really annoying
No, and no, if you don't select "do a clean install".
When installing drivers, do you do a full or custom install? If custom, what do you untick?
What about GeForce Experience? As I seen a thread on here saying it causes some issues or something.I untick 3D vision and Physx as Physx is usually the same one thats installed already
With Fast Sync enabled is it advised to set triple buffering in NVC to on and V-Sync to on in games or just Fast Sync on it's own ?
Wish nvidia would update their control panel, having to wait for around 10 seconds for anything you click to work when you first open it makes it look archaic compared to the new amd panel.
Uninstall using DDU and then install the new driver.Guys, when updating graphic card drivers these days, do you have to uninstall old first or not ? or just run the new driver software.
