Well I like it......even if it does remind me that I haven't finished the design for mine yet!
Really nice case look super clean and industrial.
Ok, so that's in-block res, pump 1, pump 2, pump 3, pump 4 (yes, count 'em!), 480 rad, back into the block in the bottom left corner to go across and I'm not sure from there....but presumably at some point it'll connect to the things that get hot
For those of us who's block doesn't exist outside of SketchUp, what sort of dimensions are you block layers and how big have you made the channels?
This is an amazing build, I have said it before I know, but great job mate.
Your build will be very unique indeed; I consider myself wholly inspired!
Cheers
Ras
Also, the block
Needs more pumps!
Wow... just wow
wow...
