Need more grunt
2 Aug 2006
Hi all
Need some idea's of an upgrade route
Will 2 x new Gpu's be sufficient to keep me in the loop with triple screen 5760x1080 gaming, my current cards are now struggling..or will i need (although dont really want to due to affordability at current time) to upgrade the core bundle parts too ?
current spec
Gigabyte Z77-D3H
i5 3570K, 3.40GHz @ 4.40GHz
2x MSI HD 7950 TFrozr III OC V2
TripleScreen 5760x1080
be interesting to know what other people with a similar setup are running too
Cheers
Its currently the best/newest card they have.
But there are things like the FuryPro (which is dual gpu on a single card) that is faster but will destroy your wallet.
Your current cards are old enough where a single, newer, powerful gfx card is going to smash them at that resolution.
Isnt that rumored to be a dual 480 card or am I reading wrong?
Do not know, but a RX480 cant be high end as it doesn't even match Nvidias GTX1070 and is likely to get smashed by a GTX1060.
P.S the 1060 nda is the 28th, so you should know more then.
