Windows 10 key?
Kyo
Kyo
11 Oct 2003
My system is almost dead :( so going to have to get a new mobo bundle. Thing I am concerned about is windows key. IIRC it's bound to your hardware right?
What is the best way to rebuild Window 10 and is it even possible if you change your hardware?
The licence for OEM is tied to the motherboard it was first installed / activated on, The Windows 10 licence goes by the original licence for that machine, you will need to purchase a new licence if you change your motherboard.
Ok thanks for clearing that up.
I still have time right? If i get my new system up and running before 28th of July. I can basically still use the free upgrade if i buy new windows 7.
Also if you buy OEM for Windows 10 is that bound to the hardware as well or would that be transferable?
Cheers
