Mobo block, should I refit
6 Jan 2013
Rollergirl
Feel like a total newb here. :o
If you look at the pictures of the pads, they look as if they have slid slightly as I've placed the block. Should I go to the trouble of reinstall or will it be fine?
Also, I didn't think so at the time but maybe I put too much paste on the South Bridge?
It'll be fine - mobo blocks are more for looks than performance anyway.
Yeah, best not to take the chance.
Not Electrically Conductive:
Arctic Silver 5 was formulated to conduct heat, not electricity.
(While much safer than electrically conductive silver and copper greases, Arctic Silver 5 should be kept away from electrical traces, pins, and leads. While it is not electrically conductive, the compound is very slightly capacitive and could potentially cause problems if it bridges two close-proximity electrical paths.)
