- 31 Oct 2005
- Leeds
really impressive work
It's actually very stable, the sides are made from 18mm MDF and everything else is 12mm MDF so that creates a fair amount of weight. Like you mentioned it has rubber feet on the base to stop it scratching anything or sliding around. Also the feet raise it slightly so the under lights can be seen.Hows the weight? Does it move around during a vigorous game of Street Fighter II or the like?
Not too much, joining the sections of lights and the odd cable extension. A lot of it is connected up with wago connectors which I was originally going to replace with soldered joins however the wagos allow for anything to be swapped out with ease.Out of interest, how much soldering is involved in a project like this?
No need to pay, plenty of free resources on the net for making cabs of all shapes and sizes, check out the BYOAC forums.I'd buy step by step instructions for this.
Already mentioned above.Would you mind telling me where you got your vinyls printed from please?![]()
I used http://rockstarprint.co.uk who printed to laminated glossy vinyl; really impressed with the quality and finish of their work.
To be honest only fired up a couple, Mario64 and Mario Kart and both seemed to play well.May I ask how you find retropi with N64 games.
Wow you do have a good memory assuming it was the large black/blue standup one I did; I only have the control panel left from that now stored away in the garage.Excellent.
I remember your Mame arcade cabinet build years ago. The finished product was epic, as is this.
