Battery help
24 Jul 2009
Hi, need a bit of help. My laptop wont power on unless I have the charger plugged in and switched on. It works fine plugged in with no battery so would I just need to replace that or could it still be the charger?
It's a MSI GT60 2PC.
Edit: Put battery in with charger and I don't the charging light doesn't come on.
Thanks
Hi there.
How old is the laptop and do you know if it is still under warranty. Given the model number I think it maybe just past the 2 year warranty period.
Purchased 12th July 2014. I registered it on the Msi website which says standard warranty plus 3 months. I'm guessing that's 12 months + 3 months, not 2 years + 3 months.
