Yeah, 2100MHz does indeed look better. But I am happy with 2000MHz. It also means lower temperature and a less stressed card![]()
Well, at the end of the day we still get Titan X-beating performance so I guess a couple of mhz doesn't really matter
It does appear 2.15ghz is the very most anyone can hope for on these on stock volts and air.
Anyone with the Gigabyte G1 version have some whine noise? Googling around it seems quite common and also annoying.
Okay perhaps I dont undrstand then, please explain to me how a 1080 drops its max boost at 50c due to TDP and not temp then please?
Also please explain why 1080s with 1.25v and kept under at low temps under 60C can reach 2300 to 2400. Surely the TDP would have racked these cards back before then?
according to gpuz my zotac extreme doesn't suffer from thermal or power limit issues, its volatage stability, that's is when I set it at 2151on the core and try to add 800 on mem
If it happens every single time at 50C, then maybe it is temp related, just I have seen no evidence of that been the case. The only video I have seen showing throttling shows nothing happening at 50C.
I also dont see it on my own card.
Whenever people have posted graphs etc. the TDP usage is always ommited.
The people who have modded their cards to use 1.25v also modded the TDP limit so its higher. Stock TDP would have no chance at 1.25v.
A thought I just had maybe its just certian vendors that do this, as then it would explain why some people see the behaviour but not others.
Has anyone registered their amp extreme online for the 5 year warranty and if so how long did it take you to get the warranty certificate back from them? I registered mine 5 days a go now but still nothing and wondering if I should chase it up or if it just takes them a bit of time to issue it.
So...the card/s clock down and thats pretty much how it is , one just has to live with it ?
