Like I said earlier mate there is no global ROM for it yet, so will come with a China ROM which has English and Chinese at stock. You can also download the Google installer for the play store etc, and uninstall any China apps you don't need. Have a look at some YouTube reviews before you buy.
Sorry for the many questions.
So does this basically mean I can just set it to UK language and it will be good to go and it will just have some Chinese apps on the phone as standard? Which as you say should be easy enough to remove?
Just trying to get my head around how much work is needed to get the phone up and going and not be bogged down with lots of Chinese apps etc.
Funnily enough i'm just watching his review now.
