 - 16 Aug 2009
Can you let me know if the 'Display Color' option tab is back in Additional Settings please?
Never mind that what about getting Hotkeys back >.<
There for me, always has tbh..
It's still available (Display Color) it just lives in a different area and uses the OS gamma control. It should have the same functionality AFAIK.
I've already shared the feedback that some users prefer the old method.
Core and Memory clocks not clocking down to 300/150 anymore with these new drivers.. its now 300/1250 and idling around 10c higher.
AMD are really starting to annoy me now.
Do you run multiple screens?
I've found previously that multiple, different screens attached to the GPU gave me raised memory clocks but switching to multiple, identical screens allowed the memory clock to drop back to the same as it did for a single screen.
Haven't installed the latest driver yet, will try to get to it this weekend and will feed back if my memory clock stays low as it does the for the previous driver or if it gets stuck at high as it did when I was running multiple different resolutions.
 running more than one display has always put the memory speed higher it's just a fact even nvidia has this. That's because they was never 300/150 to begin withrunning more than one display has always put the memory speed higher it's just a fact even nvidia has this.
One display = 300/150
Two or more = 300/1250
Reason even going back not changed this. You must have just missed this and thought you was idling at 150
Of course they were 300/150.. do you think im stupid? do you think i dont monitor these things with GPU-Z, Real Temp (GPU Monitoring) MSI Afterburner?
Im pretty OCD with these sort of stats but go ahead and tell me im wrong and that i've been seeing things for the last 4 years.
You obviously think im really stupid and have overlooked all of this but at the end of the day you havnt been on my computer and seen it for yourself.
But you carry on as i guess you're the expert around here and think its impossible for me to have these low memory clocks with 2 monitors running off my GPU.
In the end you're making yourself look stupid.
Yes the clocks were 300/150 running 2 1080p displays with 16.4.2. After trying the latest drivers and getting higher memory clocks.. i reverted back to 16.4.2 and still got higher memory clocks.. even tried DDU and a host of other tricks to get the memory clocks back down.. i give up now as im not spending my friday afternoon p****** about with GPU drivers.
I've decided to run my second 1080p monitor from the HDMI port on my Asus Z170 Pro Gaming board with the third running from the DVI on the Mobo too.. so just 1 monitor from the GPU now.
I guess its time to find out if Nvidia have the same crap going on with high memory clocks, and they obviously havnt got rid of the Gamma settings in the control panel from what i have read.
AMD need to pull their fingers out of their ***** and start leaving things how they were instead of trying to be smart.. if it aint broken then dont try and fix it.
Maybe this is their way of getting me to upgrade my 7950.. as much as i want a Sapphire Nitro 480, i was going to try and hold on to my 7950 for a bit longer and see what Vega brings..
Now i need to consider my options of moving over to the green team, i know Nvidia drivers can be just as bad but for what i want with idle clocks, Gamma settings being easy to access etc.. i have some research to do now..
At least i only need to game from the one display coming from the GPU.
For now im back on 16.4.2 as i cba with wasting anymore time today, i need to go out and do stuff.
Thanks AMD for making my afternoon a pain in the a** and putting me in a somewhat bad mood.
I run 2 displays, one on DP and the other on HDMI. One driver option I've found that influences idle memory clocks is Pixel format.
On the HDMI Display (DP cannot be changed):
YCbCr 4:2:2 150MHz
YCbCr 4:4:4 150MHz
RGB 4:4:4 (limited) 1500MHz
RGB 4:4:4 (Full) 1500MHz
Does changing pixel format on the HDMI display have the same effect on your system?
YCbCr 4:2:2 150MHz
YCbCr 4:4:4 150MHz
Anyway case closed, when i get 2 displays running off the GPU with low clocks again i'll post the evidence, something i never though i'd have to provide.
