 - 23 Sep 2009
 - London
Sleeving time!!
So I'd like to think I've gotten better at this...
Ran out of a full length of sleeving, so I had to improvise with the leftover shrink tubing and two small lengths of sleeving:
All that's really left now is the bottom two rads, and the new case feet. Unfortunately I'm still struggling to get those two rads to fit with the tubing going straight up as well as planning a drain port for each rad through the bottom of the case (the extra height due to the new case feet will allow me to stick in a 90 degree fitting on both drain ports and screw in the bitspower drain ball valves).
If i have drain ports in the floor of my case, I will need to keep the fittings on bottom rad ports completely straight to screw into the drain line's bulkhead in the case floor...that causes issues with bending the tubing with the top rad ports getting in the way no matter how I rotate it...so I will need to add some 90 degree bends on the bottom rad ports to get the tubing around the rads, however I have very limited space to work with so that might not work. This is driving me crazy!
The other option is drain ports in the front of the case, which will hurt the aesthetics somewhat so I ruled that out. I thought about drain lines going to the back of the case instead but I was worried about any leaks frying the PSU as well as the 240 rad's drain port being more difficult as the PSU is in the way of it...anyway I'll keep trying.
I'll try to post pics of what I'm trying to do...
