Weird Render/YouTube Issue
19 Feb 2007
Northampton
After I've recorded a video and rendered it out using Sony Vegas in 1440P 60FPS and uploaded it to YouTube, YouTube only shows the option for 1080P 60FPS even after waiting a number of days and I've repeated this a number of time to make sure.
I can render the exact same video with the same bit rate, Resolution, File type and frame rate with Premier Pro and YouTube only an hour or so later will give me the option for 1440P 60FPS.
Anyone by chance come across this before ?
Bit weird, I'm assuming you've been able to upload 1440p vegas-rendered files before without issue? Or are you just trying 1440p with Vegas for the first time now?
Can you screenshot your project and render settings?
Yeah I've uploaded some before with Sony and they work fine, Only lately that the 1440P option refuses to show up, Here are my settings -
Looks the same as mine, although your bit rate is very much higher and I don't tick deblocking filter (no idea what it is either :p )
I go for 20 Average and 24 Max.
IIRC: 24 is the maximum recommended by YouTube.
Might be worth trying a quick video at 20 and seeing if that gets you to 1440p on YouTube ?
