The Polaris RX 480 Owners Thread.
Man of Honour
OP
21 May 2012
Dalek flagship
Welcome and on TROH.:)
The Roll of Honour.
Date 30/07/2016, Make Sapphire Nitro+OC 8gb, MichaelM, Link
Date 29/07/2016, Make Sapphire Nitro+OC 8gb, JustEner, Link
Date 28/07/2016, Make Sapphire Nitro+OC 8gb, zophiel, Link
Date 28/07/2016, Make Sapphire Nitro+OC 8gb, merlah, Link
Date 27/07/2016, Make PowerColor Reference 8gb, Pete @r..., Link
Date 12/07/2016, Make Gigabyte Reference 8gb, xb8browney, Link
Date 12/07/2016, Make Gigabyte Reference 8gb, eNe, Link
Date 11/07/2016, Make XFX Reference 8gb, orbitalwalsh, Link
Date 09/07/2016, Make Asus Reference 8gb, Gripen90, Link
Date 05/07/2016, Make Sapphire Reference 4gb, Boomstick777, Link
Date 02/07/2016, Make Sapphire Reference 8gb, FredFlint, Link
Date 02/07/2016, Make XFX Reference 8gb, swanseajack, Link
Date 01/07/2016, Make Sapphire Reference 8gb, SouthEastBlue, Link
Date 01/07/2016, Make Sapphire Reference 8gb, KonfuciousK, Link
Date 30/06/2016, Make Sapphire Reference 4gb, Tute, Link
Date 30/06/2016, Make Sapphire Reference 8gb, Overlag, Link
Date 30/06/2016, Make Gigabyte Reference 8gb, MDPlatts, Link
Date 30/06/2016, Make XFX Reference 4gb, Bantu, Link
Date 30/06/2016, Make XFX Reference 4gb, TheLegendOfMart, Link
Date 30/06/2016, Make Sapphire Reference 8gb, montymint, Link
Date 30/06/2016, Make Sapphire Reference 8gb, roy23, Link
Date 29/06/2016, Make Sapphire Reference 8gb, stulid, Link
Date 29/06/2016, Make Sapphire Reference 8gb, Kaapstad, Link
Date 29/06/2016, Make Sapphire Reference 8gb, whyscotty, Link
Date 29/06/2016, Make Sapphire Reference 8gb, AMDMatt, Link
To get on the Roll of Honour all you have to do is post a pic with your user name on it of your RX 480.​
Caporegime
12 Jul 2007
United Kingdom
Seems to be the case with the new settings version. You will also notice that the clock slider only goes in 5% increments now rather than 0.5%
You can however revert to the old drivers to get the original WattMan then update the drivers but exclude the settings component. Then you can still clock GPU and RAM in the same way.
See my post here.
4 Jun 2016
Got my waterblock in today (XSPC blade), works great! Had a quick play with der8auer unlocked bios but windows started acting strange so removed it; got this pretty nice score at 1480/2250mhz though: http://www.3dmark.com/fs/9570827
Currently chilling at 1395/2250 which will hopefully be stable 24/7!
16 Aug 2009
Thats odd, Imgur won't display for some reason.
http://imgur.com/a/sXuKI
edit: Tinypic works though:
19 Dec 2010
Greeting all... I have had my R290p unlock to R290x since late 2013. I fancy an upgrade do you guy think it's wise to upgrade to RX480 or wait for the RX490? And what is the performance difference in crossfire?
Cheers.
Buy it. It will offer a small upgrade over the 290, use less power and have some new features. Besides it's always nice to get something new.
And, it won't cost you that much if you sell the 290.
Further down the line you can sell it on and upgrade to something else.
31 Dec 2008
Did anyone tried connecting it to 4K tv.? Every time I set it to 60Hz PC just reboots as if the reset button was pressed.
I know I should use hdmi 2.0 cable which I don't have but I thought it won't hurt to try.
In worst case it shouldn't let me choose 60hz or display anything but definitely not just reboot.
anyone.?
Man of Honour
OP
21 May 2012
Dalek flagship
The Roll of Honour.
Date 31/07/2016, Make Sapphire Nitro+OC 4gb, Blackjack Davy, Link
2 Jul 2005
Surrey
Once I sell one of my R290 I will look into this.;)
13 Mar 2008
Ireland
Everything was pretty much as expected... except witcher 3 holy hell. Was his reference 480 a 4gb card? that's a very very nice jump.
I noticed in the original 480 review on Guru3D that Polaris does much better with Gameworks effects as well. It's up there with the Fury X in Fallout 4 until you push passed 1440p
Caporegime
12 Jul 2007
United Kingdom
Primitive discard accelerator, helps when certain games use excessive levels of tessellation by discarding triangles that do not influence the rendered scene.
