The Pascal GTX 1080 Owners Thread
25 Mar 2004
Fareham
eEvBw
It's not too late to join the club is it ?
Been stuck in traffic on the way :D
for some reason it wont post my image
Bad link, you need to link the image directly.
24 Jul 2009
Lost in Alps
Just fitted ekwb block onto my EVGA 1080FE and installed.
At idle temp is 27 deg. As benchmarking noob, can anyone advise good way to bench card under load - game for 20 mins, download 3dMark/firestrike?
Also installed EVGA Precision, but I dont find the interface intuitive. Is there a quick/easy way to OC the card?
Many thanks
In EVGA Precision I maxed power limit to 120% and temp limit and applied, , reran heaven benchmark, dont see any change in GPU clock speed (around 1950 something). Any ideas?
18 Oct 2002
you need to increase the clock speed of the gpu using PX in 100mhz increments until it crashes using stock volts, then increase the volts on the right hand slider in PX in small increments until you find the maximum OC of the GPU.
10 Nov 2006
Lincolnshire
Thinking of buying the EVGA Hybrid kit for my 1080, it totally transformed my TX last time round.
Not been keeping up to date does any-one know if aftermarket bios with increase volts have been released yet for the 1080 under water?
And to liquid cooled 1080 owners what clocks are you running?
18 Oct 2002
problem is, the 1080 classified with a cherry picked chip under LN2 tops out at 2.5ghz so even with a custom bios going above 2.1ghz is going to be a rocky road.
10 Nov 2006
Lincolnshire
So my card runs around 2020/2088 depending on the game @ 72c, I'd like a see a stable 2150 and not move around on the core speed, this isn't doable with a custom bios? I know it was a problem back in June just wondering if any-ones found a way round it yet.
6 Oct 2012
Hi guys how are you
SO i tought i was stable with my 1080 SLI till test in some heavy games like GTAV and Witcher 3, after that i saw that i was not stable at all and to stabilize the SLI OC was a pain in the ass
Finally i got stable, not what i wanted but it`s what i got
2076 to start, after some degrees 2063 and after 65C 2050..... and go on
Memos 5500 Stable....
Is it a still good OC for the SLI? If i pump +5 core or +5 vcore, anything else more i get a crash in games
Here is the Afterburner picture, if you guys have some advice i`ll be thankfull, but let me know if the oc is ok to a SLI rig, the cards are EVGA SC ACX 3.0
Tks
10 Nov 2006
Lincolnshire
Nothing wrong with them O/C's at all in SLI, some people struggle to keep them solid with a single card. I'd perhaps drop it back a bit more than -5 on the core to future proof, along will come a game pritty soon and you'll hit another crash. I'd drop down to 2040 and leave it at that for a 24/7 O/C.
Gee
Gee
11 Jul 2007
I thought this was how GPU Boost 3.0 worked. I saw on r/nvidia that all you had to do was max the power and temp limit and the card would boost to it's highest stable clock. However, mine was stuck at 1947Mhz, on occasion boosting to (iirc) 2002Mhz. I upped the clock to +50Mhz and left the memory at stock which is stable now. No change in temps either.
FWIW the auto overclock on PX didn't work for me (v6.0.3).
24 Jul 2009
Lost in Alps
@Gee - as well as maxing the power and temp limit, I set offsets as follows:
GPU +200
Mem +500
First time ever clocked GPU. Card stable with GPU 2100Mhz, Mem 5500Mhz, maxed out at 47deg during Heaven benchmark with score of ~3060
I think the above clocks are good??? (EVGA 1080 FE with EKWB full block)
Caporegime
20 Jan 2005
Co Durham
GPU +200
Mem +500
Be careful of your memory. It has very good error correction and will be applied for a few 100Mhz before the memory crashes due to speed.
You might find that 5300Mhz gives faster banchmark results than 5500Mhz as at 5500Mhz more than 10% of the results are coming back as errors and have to be corrected giving you a slower effective memory speed of 5000Mhz if that makes sense?
the only way to find your max memory is increase it by 100Mhz at a time and rerun the benchmarks and as soon the benchmark starts reducing, back it off 50Mhz.
24 Jul 2009
Lost in Alps
Hi agree I, much appreciate your feedback as Im new to this. I performed multiple Heaven benchmarks, leaving gpu at +200 and incrementally increasing mem by 100. Each time score improved.
Appreciate what you say regards mem correction when having further play around and upping gpu/mem further, seeing detrimental score effect.
Looks like I did ok in silicon lottery, being under water certainly benefits.
Man of Honour
OP
21 May 2012
Dalek flagship
Welcome and on TROH.:)
The Roll of Honour.
Date 01/08/2016, Make MSI Gaming X, Vertigo1, Link
Date 01/08/2016, Make MSI Sea Hawk, Mr Lahey, Link
Date 01/08/2016, Make MSI Sea Hawk, BOBWEISER, Link
Date 31/07/2016, Make Asus Strix Gaming, rogueblade, Link
Date 31/07/2016, Make Asus Strix Gaming, LoopyOrc, Link
Date 29/07/2016, Make EVGA FTW ACX 3.0, Drollic, Link
Date 29/07/2016, Make MSI Gaming X, ronski, Link
Date 29/07/2016, Make EVGA SC ACX 3.0, Five.Stars, Link
Date 29/07/2016, Make EVGA FTW ACX 3.0, PESolution, Link
Date 28/07/2016, Make EVGA FTW ACX 3.0, soundesciple, Link
Date 27/07/2016, Make Asus Strix Gaming, CrazyArsedMonky, Link
Date 27/07/2016, Make Palit Super Jetstream, adger1971, Link
Date 25/07/2016, Make Zotac AMP Extreme Spectra, marcus2704, Link
Date 23/07/2016, Make Palit Super Jetstream, Merisimus, Link
Date 22/07/2016, Make Gigabyte G1 Gaming, oaksmokedbacon, Link
Date 22/07/2016, Make EVGA FTW ACX 3.0, Day187, Link
Date 21/07/2016, Make Palit GameRock Premier Edition, titaniumx3, Link
Date 21/07/2016, Make EVGA FTW ACX 3.0, Valenni, Link
Date 19/07/2016, Make Zotac AMP Extreme Spectra, CauseanAffect, Link
Date 16/07/2016, Make EVGA SC ACX 3.0, roge8014, Link
Date 16/07/2016, Make Palit Founders Edition, nalfylatino87, Link
Date 15/07/2016, Make EVGA FTW ACX 3.0, Gee, Link
Date 14/07/2016, Make MSI Gaming X, Pappa-D, Link
Date 11/07/2016, Make EVGA FTW ACX 3.0, Smffy, Link
Date 11/07/2016, Make EVGA FTW ACX 3.0, Simon Belmont, Link
Date 11/07/2016, Make Inno3D HerculeZ X2, bfar, Link
Date 09/07/2016, Make EVGA FTW ACX 3.0, jackle13, Link
Date 08/07/2016, Make Gigabyte G1 Gaming, ashmanuk67, Link
Date 08/07/2016, Make Palit Super Jetstream, oldestgregg, Link
Date 08/07/2016, Make EVGA FTW ACX 3.0, [Damien], Link
Date 07/07/2016, Make Palit Super Jetstream, Greebo, Link
Date 07/07/2016, Make Palit Super Jetstream, PDUK216, Link
Date 07/07/2016, Make EVGA SC ACX 3.0, Bulletzen, Link
Date 06/07/2016, Make MSI Founders Edition, GottiB, Link
Date 06/07/2016, Make Gigabyte Xtreme WaterForce, jommy999, Link
Date 04/07/2016, Make Palit GameRock Premier Edition, jjgreenwood, Link
Date 04/07/2016, Make Palit GameRock, jackass3_16, Link
Date 03/07/2016, Make Inno3D HerculeZ X2, midweek, Link
Date 03/07/2016, Make MSI Armor OC Edition, vintage-x, Link
Date 02/07/2016, Make Gigabyte Xtreme Edition, stulid, Link
Date 02/07/2016, Make Palit GameRock Premier Edition, sativa1874, Link
Date 02/07/2016, Make MSI Gaming X, Rap1D, Link
Date 01/07/2016, Make Gigabyte G1 Gaming, Westie, Link
Date 30/06/2016, Make EVGA Founders Edition, adbee, Link
Date 30/06/2016, Make Palit Super Jetstream, Scottland, Link
Date 30/06/2016, Make MSI Gaming X, DougF1, Link
Date 30/06/2016, Make Palit GameRock Premier Edition, Merisimus, Link
Date 30/06/2016, Make EVGA SC ACX 3.0, fishyswaz, Link
Date 29/06/2016, Make Zotac AMP Edition, WesleyBurns, Link
Date 28/06/2016, Make NVidia Founders Edition, OCPete, Link
Date 28/06/2016, Make MSI Gaming X, sprite-, Link
Date 27/06/2016, Make Gigabyte Founders Edition, varkanoid, Link
Date 24/06/2016, Make MSI Founders Edition, latentjones, Link
Date 24/06/2016, Make Palit Founders Edition, VEGACORTEZ, Link
Date 23/06/2016, Make MSI Gaming X, PDArm, Link
Date 23/06/2016, Make EVGA FTW ACX 3.0, tomcoleman, Link
Date 23/06/2016, Make Inno3D iChill X4 Edition, Catanonia, Link
Date 23/06/2016, Make Zotac AMP Edition, PESolution, Link
Date 22/06/2016, Make EVGA Founders Edition, Kaapstad, Link
Date 22/06/2016, Make EVGA Founders Edition, khemist, Link
Date 22/06/2016, Make Gainward Phoenix GS GLH, Jenkinio, Link
Date 22/06/2016, Make Gainward Phoenix GS GLH, sirleeofroy, Link
Date 22/06/2016, Make Inno3D iChill X4 Edition, PSeeBee, Link
Date 22/06/2016, Make Zotac Plus OC, $h@d0w, Link
Date 21/06/2016, Make Asus Strix Gaming, ThereIs0nly0ne, Link
Date 21/06/2016, Make MSI Gaming X, HungryHippos, Link
Date 21/06/2016, Make Asus Strix Gaming, Meteor, Link
Date 21/06/2016, Make MSI Sea Hawk EK, haszek, Link
Date 21/06/2016, Make MSI Sea Hawk EK, enigma27, Link
Date 21/06/2016, Make MSI Gaming X, Schwartz, Link
Date 21/06/2016, Make EVGA Founders Edition, rd_equals, Link
Date 20/06/2016, Make MSI Gaming X, Gripen90, Link
Date 20/06/2016, Make EVGA SC ACX 3.0, whyscotty, Link
Date 20/06/2016, Make MSI Founders Edition, MooKaNooBa, Link
Date 20/06/2016, Make Gainward Phoenix GS GLH, TheGez, Link
Date 20/06/2016, Make Gigabyte G1 Gaming, BlakeySFC, Link
Date 19/06/2016, Make Palit Founders Edition, evensis, Link
Date 18/06/2016, Make Gainward Phoenix GS GLH, Matty8787, Link
Date 18/06/2016, Make Zotac Founders Edition, smogsy, Link
Date 17/06/2016, Make MSI Gaming X, Rasphelt, Link
Date 16/06/2016, Make EVGA SC ACX 3.0, Gripen90, Link
Date 16/06/2016, Make Asus Strix Gaming, grav, Link
Date 15/06/2016, Make Gigabyte Founders Edition, a66as, Link
Date 15/06/2016, Make MSI Founders Edition, Born_2_Kill_83, Link
Date 15/06/2016, Make Zotac Founders Edition, Hixxy0, Link
Date 15/06/2016, Make EVGA Founders Edition, jabski, Link
Date 14/06/2016, Make MSI Gaming X, Popov, Link
Date 14/06/2016, Make EVGA Founders Edition, Devious, Link
Date 14/06/2016, Make EVGA Founders Edition, Stelly, Link
Date 13/06/2016, Make Inno3D Founders Edition, CEUOTC, Link
Date 13/06/2016, Make MSI Gaming X, JABenedicic, Link
Date 13/06/2016, Make MSI Gaming X, Cochran, Link
Date 13/06/2016, Make MSI Gaming X, JLyte, Link
Date 11/06/2016, Make Zotac Founders Edition, avatar12m, Link
Date 11/06/2016, Make EVGA Founders Edition, crinkleshoes, Link
Date 10/06/2016, Make Gigabyte G1 Gaming, BriT, Link
Date 09/06/2016, Make EVGA Founders Edition, spiralz, Link
Date 09/06/2016, Make Gigabyte Founders Edition, WesleyBurns, Link
Date 08/06/2016, Make Gigabyte G1 Gaming, Gregster, Link
Date 08/06/2016, Make Zotac Founders Edition, Biffa, Link
Date 07/06/2016, Make Gigabyte G1 Gaming, Sasahara, Link
Date 06/06/2016, Make EVGA Founders Edition, Boomstick777, Link
Date 06/06/2016, Make EVGA Founders Edition, tyler_jrb, Link
Date 05/06/2016, Make EVGA Founders Edition, danw872, Link
Date 04/06/2016, Make MSI Founders Edition, easyrider, Link
Date 04/06/2016, Make Inno3D HerculeZ X2, LewisRaz, Link
Date 03/06/2016, Make MSI Founders Edition, DAIR, Link
Date 03/06/2016, Make Palit Founders Edition, Spikey, Link
Date 02/06/2016, Make EVGA Founders Edition, Radox-0, Link
Date 31/05/2016, Make EVGA Founders Edition, toon_mad, Link
Date 31/05/2016, Make Zotac Founders Edition, ToastedChip, Link
Date 29/05/2016, Make Gigabyte Founders Edition, kitkat9933, Link
Date 28/05/2016, Make EVGA Founders Edition, X-Mikuru_Beam-X, Link
Date 28/05/2016, Make Gigabyte Founders Edition, dvs8, Link
Date 28/05/2016, Make EVGA Founders Edition, passey89, Link
Date 28/05/2016, Make MSI Founders Edition, Biomorphs, Link
Date 28/05/2016, Make EVGA Founders Edition, RichardH754, Link
To get on the Roll of Honour all you have to do is post a pic with your user name on it of your GTX 1080.​
24 Feb 2013
East Midlands
Hi guys how are you
Tks
I'd be happy with 2000/5300 in sli and settle for slightly lower temps and noise knowing its stable.
