That explains why I can run hairworks in witcher 3 then
Giz
I'm aiming to get one of these reference cards once stock calms down, but I'm concerned about a couple of the issues raised here and elsewhere (the high PCIe power draw and the need to undervolt to prevent throttling). Can these be solved via driver updates or is it better to wait for a new version (or go non-reference - bearing in mind my budget is under £200)
Also what temperatures are people seeing? A quick scan of the thread says anywhere from 80-88c under load, might cook me in my small room.
Just Installed my 480 and haven't bothered to tweak anything yet, The nitro sure looks awesome though
There you go.
I keep seeing wattman mentioned, do you have to use that now instead of afterburner with these?
Should get mine soonReplace the old 780
I dont think afterburner has been updated for the rx480 yet,so you need to use wattman,but the sapphire trixx software should be avalible soon.
Got mine yesterday. Freaks me out when both fans stop while I'm in windows. (My cup with a slightly different version of my nickname, hope it's acceptable!)
