MasterCase5 MOD: Project TRON
25 Nov 2013
UK
Main2%20Small_zpsb02wau9r.jpg~original
Hi all,
I'm very happy to be doing this MOD, Its something I have dabbled with in the past but not on a big scale.
My very first PC MOD, around 2003, was inspired by the original TRON movie, I loved the movie as a kid,
and with the help of some other movies like Blade runner and the Terminator, I was hocked on futuristic tech and sci-fi.
Here is the 1st MOD to give you a good idea how the EL wire will look.
So when CoolerMaster kindly offered me a MasterCase 5 I jumped all over it, the case is fantastic,
for anyone that's seen my project: Alternate desk build, you will already know I love the
sharp looking designs and it fits perfect with the Tron theme.
Moving on to the colours, I couldn't decide if to paint it all gloss black or white, so I'm going to paint the inside white and the outside black.
I think it will look cool but should I be wrong I might do a last minuet change to the white interior and go with all black.
The lighting is going to be a nice blue and I've also got some white,blue and UV dyes to play with for the cooling.
As always, please do let me know your thoughts as I progress.
SPECS:
Case: Cooler Master, MasterCase Maker5
Sound: Creative Sound Blaster ZXR
Storage: Crucial, MX300 750GB SSD
RAM: Crucial, 32GB kit, DDR4-3000
PSU: Cooler Master, MasterWatt Maker 1200
INCOMING:
GPU: Nvidia gtx1080 Founders edition
Motherboard: Gigabyte x99 ultra gaming
COOLING -
RAD's: EK, Coolstream SE 240 and Coolstream PE 360.
Pump: EK, XTOP Revo D5 PWM
GPU Block: EK-FC1080 GTX
CPU Block: EK, Supremacy EVO
RES: EK-RES X3 250
EK Hard Tube, compression Fittings and dyes.
LIGHTING -
EL Panel and Tape kindly provided the EL lighting for the project.
Drivers
Extensions & Splitters
EL tape's
EL wire
Big Thank You to all my sponsors and followers
Links.
nvidia_logo_horizontal_zpsixjsjrcf.jpg~original
Time to crack on! :)
The MasterCase 5's I have, One is the Pro and the other is the normal Master 5.
CoolerMaster have sent me some other accessories so I can transform the Pro in to a MasterCase Maker 5.
I will add a link to the video I did showing some differences between them and some of the accessories.
Vid:
MasterWatt Maker 1200, The biggest and most powerful PSU I've had to date.
This will easily power my setup and be ready for when I go SLI.
The PSU also comes with this Bluetooth adapter so you can monitor and change setting via the smartphone app.
For the sound I have a Creative Sound Blaster ZXR.
Although this looks great, along with some other components it's going to need some white paint.
I need to get the painting done asap, especially the gloss black so it's nice and cured before the 27th of this month, If completed in time the case will be going to the NEC for the i58 show.
For the lighting I will be mainly using EL, its very effective and a must for any tron mod :)
I have Tape, Wire, Splitters and Drivers.
They should all run fine via the 12V PSU lane, during testing I'm using battery packs to make thing easier.
Work has started on the case, I will try update the log daily until it's up to date.
Had an eye on this on Facebook, gotta love EL panels. Was going to use them myself for some light panels but I can't hide the inverters anywhere in my restructured In Win 901.
Love me some Tron.
Looking forward to seeing more of this project!!
Me also, Thanks for the reply :)
As a huge Tron fan myself I am looking forward to watching this build take shape.
Wulf
Nice! you are the man I need to impress most then :D
Going to look great!
Hope so, Thanks :)
Love me some Tron.
The EL panels are great, I have done lots with RGB, LED's and some other lighting, but you can never get as good a even light and it really pops!
Wont be too hard to hide the drivers in this case, but I can see how you might struggle. MSG me on FB if you want and we can try find a way to hide them.
For the storage I will be using a Crucial, MX300 750GB SSD
RAM Crucial, 32GB kit, DDR4-3000, This along with the SSD will be painted white.
Now for the watercooling, I ordered the white versions when possible to reduce the amount of painting needed.
EK, GTX1080 Water Block, I don't have the 1080 yet so unable to show it fitted for now :(
I have some EK, Pastel white and blue, along with some UV blue. plan is to have a mix with all 3 and try get a nice shade to match the build.
Vid showing them all unboxed:
EK-RES X3 250
Water Pump: XTOP Revo D5 PWM
For the RAD's we have a Coolstream SE 240 and Coolstream PE 360.
CPU Waterblock: EK, Supremacy EVO
Such lovely kit ready to go in.
...MSG me on FB if you want and we can try find a way to hide them.
Cheers for the offer, next time for sure. The 901 project has been in the drawing and planning stages for over a year and it's been tough enough getting a DDC in given how I'm reworking the internals :p
LED strips and heavily frosted acrylic is good enough for now given I'm only doing lit edging underneath aluminium facias.
Consider backplates for the ZxR. I had one commissioned for my build and it really helps with the finished look.
Looking great btw, subbed.
I have just received the X99 Ultra, cant wait to get this up and running, the lighting on it looks great!
Some parts are already white on the board but the red will need covering or re-painting.
I'm only waiting on the GPU now, until it arrives I will just keep working on the case, I'm also doing some
unboxings for the Tube, have lots of appointments, the i58 at the end of the month and my Birthday on the 16th,
so this is going to be a busy month.
Most of you will have seen one, if not all of the Mastercase range, fantastic cases and almost perfect for 1st time modders
and the pros.
Very solid build when compared to some of the older cases, its taken a bit more effort to make cuts in the frame for some
wires to feed though.
This is a Pro case that I have changed in to a Master Maker case via some accessories, new front and top cover, new control bay
at the top and I have a clear side (plexi), and this shown in the photos, Glass.
The glass looks best I think, however it has a slight tint to it.
Should it make things look a bit of when completed then I will go back to the standard side panel.
I think It should be fine though, but we wont know until almost the end :)
This is how it looks with all the removable parts take of, apart from the back covers.
Not a problem, and funny you mention the frosted acrylic, I ordered some before I got the tape and was going to use that for most of the
lighting effects.
I also ordered myself some white for the back of the ZxR that I can see Pete has mentioned
Looks like we are all on the same wavelength :D
Thanks Pete, as above, I have some white acrylic ready to try make a decent plate for the ZxR.
Will be my first time but im sure it will workout fine.
Its a shame that the best looking parts of the PCIe cards are almost always facing down :(
All the edges that you can see on the case and this front cover will need to have cuts made for the
EL wire to fit in about half way for a more clean look.
The sound proofing was quite easy to remove from the back of the front cover.
When the proofing was removed it reveals some holes that you can stick a screwdriver in to remove the case badge.
For the EL wire to sit nice I started of cutting the groves freehand, might be a faster and better way to do this
but with only a couple of slips repaired with some filler, it worked out ok in the end :)
I wanted to do a Tron disc in the center of the case and in doing so will allow for me to make a nice new
hole in the center of the disc to allow for a bit more air to get in and add to the overall look of the case.
Not the best hole I've ever made, just needed a quick sanding down.
This is to show you all where I plan to have the disc, if all goes to plan I will be airbrushing around the disc and blending in to the front of the case.
The top, sides and front have all had the groove treatment, took some time but worth it :)
You will also see that all the parts have been sanded down ready for primer.
Some of them slip-ups filled in with plastic putty.
Hole prep ready for when the EL wire is attached to the case.
As I mentioned before, need to get the paint down asap as the primer needs 24hrs to dry, 1st base coat 24hrs, 2nd base coat 5 to 7 days before a final sanding, then the 1st clear coat 3 days and more sanding, and finally the top clear with around 7 days before a final sand and buff in order to get the best shine possible.
You will see some parts are in the grey or white primer stages, the inside parts will be white, outer black.
Don't think I will be using the fan, but did it anyway just encase lol
2nd coat of primer done, forgot to mention that. so add another 24hrs :(
As the case was in the 24hrs stage I moved on to the components, SSD, RAM and sound card.
Forgot to upload the sound card photos so I will add them when I next update the log.
1st coat of white plastic-dip.
The covers are now painted white, not sure if I will be adding gloss to the inside, I will see how it looks later in the build before deciding.
1st coat of black has been done, I now need to get them all sanded down and add a 2nd coat.
