RX 480 without a doubt.hey guys,
thanks for the reply, im now torn between the RX 480 and GTX 970. what one will give me better frames and longevity?
RTJ
You mentioned that you only play Counter Strike which the 380X can run that game without any problems.
i play ARMA and wanna start playing some more demanding games, so sorry to add one more thing into the mix..
but for prices, the 1060 is in the same ballpark and is that better than the RX 480?
RTJ
Get the card that's best now. Why buy something in the hope it "might" get quicker later down the line? What if it doesn't? What if you upgrade before it ever comes good?
The 1060 is cooler, quieter and uses less power albeit it's more expensive. Please don't think of this as a one sided argument but I think too many people put faith in waiting for the next best thing... sometimes you need to get what's right for now.
I would take a 1060 over a 480. Good benchmarks here
Essentially in dx11 titles the 1060 is getting plus 10-14% and in some (not all!) dx12 titles the 480 is gaining less than 5%.
I said a while back that an AMD card would generate more heat, draw more power and run slower than its competition but I did say it would be cheaper. Now admittedly I only based this 'speculation' on history but it's good to say AMD are at best consistent!
By all means sit there hoping it will get faster.
It is simple really, if you are likely to keep the new card for more than a year and a half then get the 480, if not the 1060 will give better performance now and over the next months.
