The Pascal GTX 1080 Owners Thread
3 Jul 2012
So I was on the pre-order for the Asus Strix 1080 OC (like so many others) and I bailed a couple of weeks ago and got the Gigabyte G1.
I had already put in another preorder for the Strix and Zotac Extreme from the rainforest and didn't cancel (both were around £620)
My plan was to see how this performs and then decide if I'd sell it and keep the other one.
I have a couple of questions
I can only seem to get the G1 up to 1761/1900 is that a limitation of the single 8 pin power?
My ram is showing as 10010 I'm guessing with the GDDR5 that makes it 50050??
I have set the fan to turbo to keep the heat down but running ultra @5760x1200 on GTA V the fans are quite loud ~65%
Is it worth me holding on for the Strix OC (est End of August) or the Zotac??
21 Feb 2006
Watched this the other day
Looks good if you're not going to be overclocking yourself, but otherwise seems a bit too expensive as it overclocks to around the same level as the other 1080s?
24 Feb 2013
East Midlands
Most non-ref cards should do 2000mhz boost or more. Mine needs +30 (1890mhz) to hit 2000mhz on the dot after extended periods in warm temps. Initially it's higher than this. You're ram will be 5005mhz. That resolution is silly :D
27 Feb 2015
Is this any good? Playing around with overwatch running in the background.
can I ask how did you get 2 graphs to show at the same time like that?
Also is that a zotac card? power usage looks wicked low for the clock although you are using a version of afterburner that doesnt support pascal.
3 Jul 2012
I just did a quick bench and it looks like boost is around 2025, Mine is on +65MHz
And oops I got a shipped notification on the Zotac Extreme :eek:
Yeah 5760x1200 is because I have 3 x 24" 1920x1200 screens :p
Man of Honour
OP
21 May 2012
Dalek flagship
Welcome and on TROH.:)
The Roll of Honour.
Date 08/08/2016, Make EVGA FTW ACX 3.0, kthula666, Link
Date 01/08/2016, Make MSI Gaming X, Vertigo1, Link
Date 01/08/2016, Make MSI Sea Hawk, Mr Lahey, Link
Date 01/08/2016, Make MSI Sea Hawk, BOBWEISER, Link
Date 31/07/2016, Make Asus Strix Gaming, rogueblade, Link
Date 31/07/2016, Make Asus Strix Gaming, LoopyOrc, Link
Date 29/07/2016, Make EVGA FTW ACX 3.0, Drollic, Link
Date 29/07/2016, Make MSI Gaming X, ronski, Link
Date 29/07/2016, Make EVGA SC ACX 3.0, Five.Stars, Link
Date 29/07/2016, Make EVGA FTW ACX 3.0, PESolution, Link
Date 28/07/2016, Make EVGA FTW ACX 3.0, soundesciple, Link
Date 27/07/2016, Make Asus Strix Gaming, CrazyArsedMonky, Link
Date 27/07/2016, Make Palit Super Jetstream, adger1971, Link
Date 25/07/2016, Make Zotac AMP Extreme Spectra, marcus2704, Link
Date 23/07/2016, Make Palit Super Jetstream, Merisimus, Link
Date 22/07/2016, Make Gigabyte G1 Gaming, oaksmokedbacon, Link
Date 22/07/2016, Make EVGA FTW ACX 3.0, Day187, Link
Date 21/07/2016, Make Palit GameRock Premier Edition, titaniumx3, Link
Date 21/07/2016, Make EVGA FTW ACX 3.0, Valenni, Link
Date 19/07/2016, Make Zotac AMP Extreme Spectra, CauseanAffect, Link
Date 16/07/2016, Make EVGA SC ACX 3.0, roge8014, Link
Date 16/07/2016, Make Palit Founders Edition, nalfylatino87, Link
Date 15/07/2016, Make EVGA FTW ACX 3.0, Gee, Link
Date 14/07/2016, Make MSI Gaming X, Pappa-D, Link
Date 11/07/2016, Make EVGA FTW ACX 3.0, Smffy, Link
Date 11/07/2016, Make EVGA FTW ACX 3.0, Simon Belmont, Link
Date 11/07/2016, Make Inno3D HerculeZ X2, bfar, Link
Date 09/07/2016, Make EVGA FTW ACX 3.0, jackle13, Link
Date 08/07/2016, Make Gigabyte G1 Gaming, ashmanuk67, Link
Date 08/07/2016, Make Palit Super Jetstream, oldestgregg, Link
Date 08/07/2016, Make EVGA FTW ACX 3.0, [Damien], Link
Date 07/07/2016, Make Palit Super Jetstream, Greebo, Link
Date 07/07/2016, Make Palit Super Jetstream, PDUK216, Link
Date 07/07/2016, Make EVGA SC ACX 3.0, Bulletzen, Link
Date 06/07/2016, Make MSI Founders Edition, GottiB, Link
Date 06/07/2016, Make Gigabyte Xtreme WaterForce, jommy999, Link
Date 04/07/2016, Make Palit GameRock Premier Edition, jjgreenwood, Link
Date 04/07/2016, Make Palit GameRock, jackass3_16, Link
Date 03/07/2016, Make Inno3D HerculeZ X2, midweek, Link
Date 03/07/2016, Make MSI Armor OC Edition, vintage-x, Link
Date 02/07/2016, Make Gigabyte Xtreme Edition, stulid, Link
Date 02/07/2016, Make Palit GameRock Premier Edition, sativa1874, Link
Date 02/07/2016, Make MSI Gaming X, Rap1D, Link
Date 01/07/2016, Make Gigabyte G1 Gaming, Westie, Link
Date 30/06/2016, Make EVGA Founders Edition, adbee, Link
Date 30/06/2016, Make Palit Super Jetstream, Scottland, Link
Date 30/06/2016, Make MSI Gaming X, DougF1, Link
Date 30/06/2016, Make Palit GameRock Premier Edition, Merisimus, Link
Date 30/06/2016, Make EVGA SC ACX 3.0, fishyswaz, Link
Date 29/06/2016, Make Zotac AMP Edition, WesleyBurns, Link
Date 28/06/2016, Make NVidia Founders Edition, OCPete, Link
Date 28/06/2016, Make MSI Gaming X, sprite-, Link
Date 27/06/2016, Make Gigabyte Founders Edition, varkanoid, Link
Date 24/06/2016, Make MSI Founders Edition, latentjones, Link
Date 24/06/2016, Make Palit Founders Edition, VEGACORTEZ, Link
Date 23/06/2016, Make MSI Gaming X, PDArm, Link
Date 23/06/2016, Make EVGA FTW ACX 3.0, tomcoleman, Link
Date 23/06/2016, Make Inno3D iChill X4 Edition, Catanonia, Link
Date 23/06/2016, Make Zotac AMP Edition, PESolution, Link
Date 22/06/2016, Make EVGA Founders Edition, Kaapstad, Link
Date 22/06/2016, Make EVGA Founders Edition, khemist, Link
Date 22/06/2016, Make Gainward Phoenix GS GLH, Jenkinio, Link
Date 22/06/2016, Make Gainward Phoenix GS GLH, sirleeofroy, Link
Date 22/06/2016, Make Inno3D iChill X4 Edition, PSeeBee, Link
Date 22/06/2016, Make Zotac Plus OC, $h@d0w, Link
Date 21/06/2016, Make Asus Strix Gaming, ThereIs0nly0ne, Link
Date 21/06/2016, Make MSI Gaming X, HungryHippos, Link
Date 21/06/2016, Make Asus Strix Gaming, Meteor, Link
Date 21/06/2016, Make MSI Sea Hawk EK, haszek, Link
Date 21/06/2016, Make MSI Sea Hawk EK, enigma27, Link
Date 21/06/2016, Make MSI Gaming X, Schwartz, Link
Date 21/06/2016, Make EVGA Founders Edition, rd_equals, Link
Date 20/06/2016, Make MSI Gaming X, Gripen90, Link
Date 20/06/2016, Make EVGA SC ACX 3.0, whyscotty, Link
Date 20/06/2016, Make MSI Founders Edition, MooKaNooBa, Link
Date 20/06/2016, Make Gainward Phoenix GS GLH, TheGez, Link
Date 20/06/2016, Make Gigabyte G1 Gaming, BlakeySFC, Link
Date 19/06/2016, Make Palit Founders Edition, evensis, Link
Date 18/06/2016, Make Gainward Phoenix GS GLH, Matty8787, Link
Date 18/06/2016, Make Zotac Founders Edition, smogsy, Link
Date 17/06/2016, Make MSI Gaming X, Rasphelt, Link
Date 16/06/2016, Make EVGA SC ACX 3.0, Gripen90, Link
Date 16/06/2016, Make Asus Strix Gaming, grav, Link
Date 15/06/2016, Make Gigabyte Founders Edition, a66as, Link
Date 15/06/2016, Make MSI Founders Edition, Born_2_Kill_83, Link
Date 15/06/2016, Make Zotac Founders Edition, Hixxy0, Link
Date 15/06/2016, Make EVGA Founders Edition, jabski, Link
Date 14/06/2016, Make MSI Gaming X, Popov, Link
Date 14/06/2016, Make EVGA Founders Edition, Devious, Link
Date 14/06/2016, Make EVGA Founders Edition, Stelly, Link
Date 13/06/2016, Make Inno3D Founders Edition, CEUOTC, Link
Date 13/06/2016, Make MSI Gaming X, JABenedicic, Link
Date 13/06/2016, Make MSI Gaming X, Cochran, Link
Date 13/06/2016, Make MSI Gaming X, JLyte, Link
Date 11/06/2016, Make Zotac Founders Edition, avatar12m, Link
Date 11/06/2016, Make EVGA Founders Edition, crinkleshoes, Link
Date 10/06/2016, Make Gigabyte G1 Gaming, BriT, Link
Date 09/06/2016, Make EVGA Founders Edition, spiralz, Link
Date 09/06/2016, Make Gigabyte Founders Edition, WesleyBurns, Link
Date 08/06/2016, Make Gigabyte G1 Gaming, Gregster, Link
Date 08/06/2016, Make Zotac Founders Edition, Biffa, Link
Date 07/06/2016, Make Gigabyte G1 Gaming, Sasahara, Link
Date 06/06/2016, Make EVGA Founders Edition, Boomstick777, Link
Date 06/06/2016, Make EVGA Founders Edition, tyler_jrb, Link
Date 05/06/2016, Make EVGA Founders Edition, danw872, Link
Date 04/06/2016, Make MSI Founders Edition, easyrider, Link
Date 04/06/2016, Make Inno3D HerculeZ X2, LewisRaz, Link
Date 03/06/2016, Make MSI Founders Edition, DAIR, Link
Date 03/06/2016, Make Palit Founders Edition, Spikey, Link
Date 02/06/2016, Make EVGA Founders Edition, Radox-0, Link
Date 31/05/2016, Make EVGA Founders Edition, toon_mad, Link
Date 31/05/2016, Make Zotac Founders Edition, ToastedChip, Link
Date 29/05/2016, Make Gigabyte Founders Edition, kitkat9933, Link
Date 28/05/2016, Make EVGA Founders Edition, X-Mikuru_Beam-X, Link
Date 28/05/2016, Make Gigabyte Founders Edition, dvs8, Link
Date 28/05/2016, Make EVGA Founders Edition, passey89, Link
Date 28/05/2016, Make MSI Founders Edition, Biomorphs, Link
Date 28/05/2016, Make EVGA Founders Edition, RichardH754, Link
To get on the Roll of Honour all you have to do is post a pic with your user name on it of your GTX 1080.​
24 Jul 2009
Lost in Alps
As far as I understand, with Pascal it's not so much number of power pins as it is susceptibility to heat?
I have an EVGA 1080FE under water, it boosts to 2100 (+200), with mem @ 5500 (+500), with Heaven benchmark temps maxxed out at 59 deg.
Caporegime
20 Jan 2005
Co Durham
Correct. There are only two things which differ between cards and that is heat and TDP.
I think the zotac and GLH both have higher TDP than other cards which enables higher stable boosts but they both also have the best air coolers and can keep the temps low enough so they dont throttle.
You still have a lottery on the actually silicon itself as to whether you get just over 2000 or over 2100.
I have seen several cards drop their max boost slightly at 50C so if you can keep the card below that then you have the max boost for your chip.
I have seen claims made that the FE have a better bios and that 2050 on a FE card is as fast in benchmarks as 2300 on an AIB card but I have yet to see absolute proof of this.
7 Aug 2016
Could I ask the opinion of you 1080 owners. I'm upgrading from a 1070 gaming x, and have got 2 founders 1080s to go sli. I managed to get them for £436 and £525, so £961 total. I thought that was a pretty good deal, however I have a zotac amp extreme on preorder from the rainforest for £575, which is also a good deal, and if I sold the others and got a second amp extreme I'd probably be looking at about £1150 sli.
I'm looking to maximise the use of my 1440p 144hz monitor for battlefield 4 and ultimately bf1 in November. Happy as long as it's usually over 120fps, but would also like to forget about upgrading for a couple of years.
What would you guys do with your 1080 hindsight?
Thanks
Martin
(Don't know how to add my setup to my flair thingy, my setup- asus x99a usb3.1, i7 6800k 4.4ghz, msi 1070 gaming x 16gb 2666 ram, nzxt h440, Samsung m.2 256gb, 500gb 850evo, dell 27" 1440p 144hz g-sync)
24 Feb 2013
East Midlands
Thanks
Martin
Blower type standard reference cards are normally more suited to sli configurations as the heat is mostly sent outside the case unlike a lot of none reference cards. You would need really good airflow for anything other than reference, especially in summer.
7 Aug 2016
Yes that was the only other thing drawing me to Fe, other than the price. Flicking through reddit some would suggest 3rd party cards in sli are much better for sli if you have the room, which I would assume I have in a h440, but maybe they're talking about massive towers. I wouldn't be rushing to oc the Fe cards as I'm noob at it, and would consider aio water if I did. Just wanted to check with experienced people if I'm missing an opportunity with the amp extremes.
Man of Honour
OP
21 May 2012
Dalek flagship
The Roll of Honour.
Date 08/08/2016, Make Zotac AMP Extreme Spectra, Shockwave, Link
2 Sep 2008
Well I was going to wait until I could find a Zotac Amp Extreme in stock somewhere with a price that wasn't extracting the urine (£695 is ridiculous) but I saw that overclockers were doing the Palit Super Jetstream for 7% off making it a decent £599.99 so I've taken the plunge and will be getting it tomorrow :D
Am just wondering what the best overclocking software is and whether the latest NVidia drivers are any good..?
Now begins the mad rush to pay off my credit card before I can get myself a Rift lol :D
