- 10 Nov 2006
- Lincolnshire
Lol'd
one or two degree delta isnt to be sniffed at!
On that basis that's the difference between the best and the worst waterblocks anyway
Remember, depending on your waterloop having another degree or two delta can make a massive difference to the final temp of your core and vrms.
EK with backplate was 6 degree delta on vrm on 980ti
Aqua with backplate is only 3 degree with active backplate (4 degree with normal)
That's double the cooling performance. No idea what this might equate to in the difference in final vrm temps and will be dependant on your loop.
The downside is the core delta.
On the 980ti the ek block gives you a delta of 7.86 degrees and the aqua is only 8.97 degrees on the core.
The big question though, which is going to be better for bigger overclocks? Cooler core or cooler vrms?????
vrms are good for 120c+ so I say the core.
Mine arrived today, although wife wasn't happy about the transport situation back from the depot.... XD
Cheers
Ras
ROH me!
True but reading around people said better cooling on vrms on 980ti achieved better overclocks.
The core is good for 90C on Titan and any decent waterblock will keep it under 60C. Will the EK perhaps giving you 55C get you a better overclock? Perhaps not.
However, having your vrms at 60C instead of 90C may make a big difference despite both been well under the 120C limit.
No idea if that applies to Pascal though.
Im too impatient to wait for people to get theirs or reviews though![]()
Keeping the VRMs cool is always a good idea. Even if they can handle 120C it is still extra heat that will find it's way to the rest of the card hindering performance.
So you would recommend the block with the far superior vrm cooling then?
^ he broke the rules! That could be anybody's wife
I demand another pic of his wife holding his username before his entry is valid![]()
Mine arrived this morning!
@Kered_Dub Just use Parcel Motel. Worked for me. They went to the Northern Ireland address and then down to me in the south.
EK. It will keep the VRMs cool enough for sure. There will also be an EK active backplate before long like the rest of their GPU line up. 1-2c on the VRMs won't make any difference.
Just go for the block you like the look of most.
For me EK looks better and are of fantastic quality. That's why I always use them. Not a fan at all of the AQ blocks.
Cheers
Ras
ROH me![/QUOTE]
:D:D:D
After spending more than 2K on graphics cards she is more likely to be holding him by the throat in the next pic.![]()
its 3C delta though not just 3 degrees. That could equate to 10C or more on the VRM.
And AQ have always been much better quality than EK..................
