Watercooled Case Gallery
9 Feb 2009
Yeah also less £20+ fans to buy lol
One last question would you go AIO or Air in the S340 Khemist m8?
I am considering this for the S340 Alphacool 280mm Eisbaer Modular AIO Hydro/Water Cooler
9 Nov 2006
Earth
Because of my last nightmare with the pump noise probably air, i'm kind of sick of watercooling for now, no doubt i will get back into it.
The amount of watercooling gear i have would be such a waste not to keep on with it.
This Bequiet cooler is doing a great job considering i have the fans the wrong way.
9 Feb 2009
Yeah was thinkg of that in the S340 but its a tad to big for the s340
It may have to be Noctua D15S and wait for the covers coming out
Kei
Kei
24 Oct 2008
South Wales
Two and a half years down the road since building my Primo. The water level has dropped a bit, but that's expected. Needs a good dusting every 6 months or so but otherwise, it's been maintenance free since building it. The tubing is fairing much better than the xspc I had before but I think it is starting to discolour.
OP
18 Oct 2002
Aranyaprathet, Thailand
I'm almost embarrassed as the OP of this amazing gallery to post today's mini effort but whatever.
So this is a H110 fitted via a Kraken G10 to a Zotac GTZ970. The rest of the machine is purely to provide a home for the 970 that folds for OCUK 24/7 hence the water. So apologies for the rest of the system.
For those who've not seen the G10 or tried one, it took me around an hour to remove the GTX970 air-cooler and fit the G10 and the H110. With the block/pump on a GPU the usual mounting places aren't easy to get to and luckily for me the 280 rad fitted very nicely resting up against that lower drive cage with no need to fix it to anything. Temps are nicely down from the standard 80C of a fully-loaded Nvidia to around half of that with only one fan on the radiator.
25 Sep 2012
Deep Blue
Corsair Carbide 540 case
Corsair Hx750i
Photon 170 D5
Corsair AF120 LED Blue fans
EK Slim Triple Radiator
Primochill 13/10 acrylic tubes
Primochil Revolvers
Botspower 90 degree fittings
ASUS MAXIMUS VIII
Intel i7 Skylake 6700k
64GB DDR4
NVIDIA GTX1080FE
Samsung Pro 500GB M.2
ASUS RAIDR 250GB
Crucial 500GBx2 RAID0
Blood, sweat, many tears and even more swearing.
27 Aug 2016
First water cooled build
Just finished my build. Waiting for some PWM extension cables to sort fans
i7-6700
MSI Z170 Gaming 7
32GB G.Skill 2666
EVGA 1070 Founders Edition
Samsung 950 Pro 512GB
6* Seagate 4TB
Thermaltake Core X9 Chassis
Corsair HX750i
EKWB S360 kit
EKWB 1070 Block
EKWB Blood Red Coolant
Will see how this goes, but would like to upgrade to acrylic tubing at some stage as the soft tubing just doesn't look as good as the acrylic stuff
27 Aug 2016
i7-6700
MSI Z170 Gaming 7
32GB G.Skill 2666
6* Seagate 4TB
Corsair HX750i
EKWB S360 kit
EKWB 1070 Block
I dont like the way the flexi tube looks.
Can someone please advise how I can route acrylic in my build to make it looks better?
Is my GPU and CPU connected the right way round? Doesnt look right with the tube from left on CPU to right on GPU?
Thanks in advance
