The Pascal GTX 1070 Owners Thread
30 Jan 2007
PA, USA (Orig UK)
Well I just flashed my non-OC Strix to an OC. Power target now showing 120 instead of only 112 etc.
Flashed my Asus Strix 1070 (non-OC) with the OC bios. Eventually I worked out that I needed 5.292 version: https://www.techpowerup.com/downloads/2709/nvflash-5-292-0-for-windows/mirrors
*** IF RUNNING 64 WINDOWS MAKE SURE YOU DON'T COPY ACROSS THE 32-bit SYS FILE***
** IMPORTANT: DO THIS AT YOUR OWN RISK. I TAKE NO RESPONSIBILITY FOR YOU BREAKING YOUR CARD AND ACCEPT NO LIABILITY**
Follow the instructions and put that in a folder called nvflash on the C drive along with the rom. ***BACK UP YOUR ORIGINAL BIOS ****
DISABLE YOUR 1070 ADAPTER IN DEVICE MANAGER
Open a CMD window with Administrator permisions.
Then use these 3 commands:
nvflash -i0 --protectoff
nvflash -i0 -6 Asus.rom (Where Asus.rom is the name of the rom file to flash).
nvflash -i0 --protecton
RE-ENABLE 1070 adapter in device manager.
Reboot your PC, and cross your fingers.
30 Jan 2007
PA, USA (Orig UK)
I don't get artifacting, but running firestrike extreme in the second test it just quits and says "cancelled by user". Hmm.....
EDIT: Rebooted and did a custom fan profile and increased power by +100. Card ran Time Spy DX12 just fine, and was boosting to 2050Mhz, which is at least 100mhz more than previously.
EDIT2: Firestrike Extreme still keeps saying "Test Cancelled by User a short way into the second test". Hmm. Need to figure out if this is a glitch or a card issue (hence it isn't an 'OC' version because it didn't make the cut). (EDIT in and EDIT lol: This might be a bug with another program causing it to bail... I read someone using afterburner had this issue, but I am using GPU Tweak II).
TNA
TNA
Caporegime
13 Mar 2008
Greater London
Would that be cost effective ?
I'll answer that for you. No.
Did I say that would be cost effective?
I'll answer that for you. No ;)
Ask Kaapstad if it is cost effective to buy a 4x 480, 1060, 1080 and Titan X Pascal. Even though he says he is more into gaming side of things :p
Cost effective has nothing to do with what I was talking about. It is called Overclockers UK for a reason, people like to see what the highest their cards can OC stable.
That said I am actually a price for performance guy myself and no I would never watercool this card. It is barley audible as it is and 50-100MHz in pascal barely makes any difference to performance anyway.
Man of Honour
OP
21 May 2012
Dalek flagship
Can me and Zotac come into play please :)
Welcome and on TROH.:)
The Roll of Honour.
Date 09/08/2016, Make Zotac AMP Edition, Kayjay333, Link
Date 07/08/2016, Make Inno3D iChill X3 Edition, RobinGopher, Link
Date 07/08/2016, Make Zotac AMP Edition, dunno, Link
Date 07/08/2016, Make Asus Strix, Scougar, Link
Date 03/08/2016, Make KFA2 Reference, pulsemyne, Link
Date 03/08/2016, Make EVGA FTW, Scramz, Link
Date 03/08/2016, Make Palit Dual Fan, melmac, Link
Date 01/08/2016, Make Zotac AMP Extreme Edition, Rom, Link
Date 30/07/2016, Make Inno3D Founders Edition, MOOGLEYS, Link
Date 30/07/2016, Make Palit Jetstream, Ogi, Link
Date 30/07/2016, Make Zotac AMP Extreme Edition, NinjaCool, Link
Date 29/07/2016, Make Palit Dual Fan, Bishie, Link
Date 29/07/2016, Make Palit Dual Fan, heatonpkmassive, Link
Date 28/07/2016, Make Zotac Founders Edition, _Jimlad_, Link
Date 27/07/2016, Make MSI Gaming X, Ex3cut3r, Link
Date 23/07/2016, Make EVGA FTW, Aretak, Link
Date 23/07/2016, Make Zotac AMP Extreme Edition, Defiant306, Link
Date 22/07/2016, Make Zotac AMP Extreme Edition, C6ckneyGeezer, Link
Date 22/07/2016, Make Zotac AMP Extreme Edition, Bickaxe, Link
Date 22/07/2016, Make KFA2 EXOC, MeatLoaf, Link
Date 22/07/2016, Make Palit Super Jetstream, Troop, Link
Date 22/07/2016, Make Asus Founders Edition, ah9098, Link
Date 22/07/2016, Make EVGA Founders Edition, Kaapstad, Link
Date 21/07/2016, Make EVGA FTW, clone, Link
Date 21/07/2016, Make MSI Gaming X, Gripen90, Link
Date 19/07/2016, Make Zotac AMP Extreme Edition, XeNoNF50, Link
Date 15/07/2016, Make KFA2 HOF, Solidair, Link
Date 18/07/2016, Make MSI Gaming X, Amatsubu, Link
Date 18/07/2016, Make Zotac AMP Extreme Edition, Jono8, Link
Date 16/07/2016, Make Palit GameRock Edition, Raikiri, Link
Date 16/07/2016, Make Gigabyte G1 Gaming, foster grant, Link
Date 16/07/2016, Make Zotac AMP Extreme Edition, tommybhoy, Link
Date 16/07/2016, Make Zotac AMP Extreme Edition, TNA, Link
Date 15/07/2016, Make KFA2 EXOC, Darren_uk, Link
Date 14/07/2016, Make MSI Gaming X, Troezar, Link
Date 14/07/2016, Make Zotac AMP Edition, Mario, Link
Date 13/07/2016, Make Zotac AMP Extreme Edition, MarkeR, Link
Date 13/07/2016, Make Gigabyte G1 Gaming, foster grant, Link
Date 10/07/2016, Make Gigabyte Windforce 2x, wellibob, Link
Date 10/07/2016, Make Gainward Phoenix Golden Sample, roddypoddy, Link
Date 08/07/2016, Make Palit GameRock Premier Edition, chrcoluk, Link
Date 08/07/2016, Make Palit GameRock Premier Edition, JTrickle, Link
Date 08/07/2016, Make Zotac AMP Edition, gtw1212, Link
Date 07/07/2016, Make MSI Gaming X, magicoi, Link
Date 06/07/2016, Make MSI Aero OC Edition, Amatyr, Link
Date 06/07/2016, Make MSI Gaming X, divinebeetle, Link
Date 04/07/2016, Make MSI Gaming X, i_am_jon, Link
Date 04/07/2016, Make Palit GameRock Premier Edition, Phil87, Link
Date 03/07/2016, Make MSI Gaming X, V_R, Link
Date 03/07/2016, Make Palit GameRock Premier Edition, foxyfaefife, Link
Date 03/07/2016, Make MSI Armor OC Edition, chris-82, Link
Date 02/07/2016, Make Palit GameRock Premier Edition, razorpakk, Link
Date 02/07/2016, Make Palit GameRock Premier Edition, styuR, Link
Date 02/07/2016, Make MSI Armor OC Edition, Shawreyboy, Link
Date 02/07/2016, Make Gigabyte G1 Gaming, Gripen90, Link
Date 01/07/2016, Make Gainward Phoenix Golden Sample, shrek2, Link
Date 01/07/2016, Make NVidia Founders Edition, BornEvil, Link
Date 30/06/2016, Make Gainward Phoenix Golden Sample, thefogo, Link
Date 30/06/2016, Make MSI Gaming X, Carta, Link
Date 29/06/2016, Make Zotac AMP Edition, Charlatan, Link
Date 29/06/2016, Make MSI Gaming X, Daaaveee, Link
Date 29/06/2016, Make MSI Gaming X, Aretak, Link
Date 29/06/2016, Make Inno3D iChiLL X3 Edition, leerogers00, Link
Date 28/06/2016, Make MSI Gaming X, DougF1, Link
Date 28/06/2016, Make MSI Armor OC Edition, markoboyo11, Link
Date 27/06/2016, Make Zotac AMP Edition, Mangochutney, Link
Date 25/06/2016, Make MSI Armor OC Edition, BornEvil, Link
Date 23/06/2016, Make MSI Aero OC Edition, McGraw, Link
Date 22/06/2016, Make MSI Armor OC Edition, smithy83, Link
Date 21/06/2016, Make MSI Armor OC Edition, Phixsator, Link
Date 20/06/2016, Make Palit Founders Edition, Paul_cz, Link
Date 20/06/2016, Make NVidia Founders Edition, Dave2150, Link
Date 20/06/2016, Make MSI Gaming X, AthlonXP1800, Link
Date 20/06/2016, Make Gigabyte G1 Gaming, w00dy85, Link
Date 19/06/2016, Make MSI Gaming X, kully1972, Link
Date 18/06/2016, Make MSI Gaming X, AliGoz, Link
Date 17/06/2016, Make MSI Gaming X, philo-sofa, Link
Date 16/06/2016, Make Palit Founders Edition, Biffa, Link
Date 16/06/2016, Make EVGA Founders Edition, Daaaveee, Link
Date 14/06/2016, Make EVGA Founders Edition, mankycrack, Link
Date 13/06/2016, Make NVidia Founders Edition, !bluetonic!, Link
Date 12/06/2016, Make MSI Founders Edition, yoyo59, Link
Date 11/06/2016, Make MSI Founders Edition, JamesM, Link
To get on the Roll of Honour all you have to do is post a pic with your user name on it of your GTX 1070.​
25 Mar 2003
Scotland
My Zotac Amp Edition has faulty fans so is going back. I think one of them is off balance so at 80% fan speed the card vibrates and the card makes a weird sound. The sound only goes away when the fan slows back down to 60%.
I've ordered a Zotac Amp Extreme. Hopefully there are no off balance fans in that thing!
TNA
TNA
Caporegime
13 Mar 2008
Greater London
Hopefully not. But you will definitely have the fan revving issue which you will hear unless you have case fans setup very high, so be prepared to run MSI Afterburner and make a custom fan profile :D
25 Mar 2003
Scotland
Ha , cheers for the tip. As long as it doesn't vibrate I'll be happy!
V_R
V_R
17 Jan 2007
UK
They don't mention the OC armor versions, and I've not had any artifacting on mine (apart from the driver bug that nvidia put out a hot fix for). Lets hope it's just a few GPUs not an MSI board design issue. Isn't the OC armor basically the same PCB as the GamingX but with less power and VRMS?
Sorry missed this earlier. yes lets hope so, and I don't know for sure but I would assume so maybe?
18 Oct 2002
Kent
Does anyone have any opinions on the Palit Super Jetstream for £400 and the Zotac Amp Spectra for £430?
The Palit is supposed to be the quieter card but the Zotac has a better warranty and I just can decide between the two.
Deleted member 2277
D
Deleted member 2277
The Palit Super Jet Stream is a really nice card, it has samsung memory and is really quiet. Mine will oc to 2100/4700. Some people have reported Palit 1070's failing after a few hours use though. The zotac cards have good reviews but there is a problem with the fans stop/starting so you have to create a custom profile.
6 Jul 2015
My Amp extreme has some slight rattle from one of the fans at about 1900rpm, so I set a fan profile to avoid that speed. Reluctant to return it as it sits happily at 2152/9500 (settles down to 2126 after a while though)
