Hi,
I currently have a PC build that is very quiet/silent which is really useful if I need to leave it on.
The graphics card is a GeForce GTX 750 Ti. Its the fanless one:
Palit Geforce GTX 750 Ti Kalmx Silent 2GB GDDR5 Card, NE5X75T00941-1073H
The motherboard used is a GA-Z97X-UD3H LGA1150 ATX Motherboard
http://uk.gigabyte.com/products/product-page.aspx?pid=4960#ov
I'm finding that some games seem to struggle a bit with this card, and the NVIDIA control panel that automatically sets the video options on your games to be optimal for the card can struggle with some settings.
The games that arent ideal include the new DOOM and No Mans Sky.
Does anyone have a recommendation for a more powerful graphics card that wouldnt make much difference to the noise from the PC? (Which is currently borderline non-existent).
Thanks for any pointers.
With MSI Afterburner you could set a fan speed % you want in the fan curve then use the temp target slider to stop it getting too warm. This is what I use on my 1060 and 1070 to keep them quiet while still maintaining high boost clocks under full load.
