- 15 Feb 2003
- Europe
Unless you're doing Crib goch Snowden is basically a walk. You see people running up it, and others carrying children in harnesses on their backs.
I did Pygs track on the way up last time I went, and back down Miners track. It's about 7-8 miles in total.
I was luck with the weather, but it can turn nasty so carry waterproof gear and something warm. There were signs at the bottle recommending 3-5 litres of water but 2 should be enough if you drink before and after as well.
You should be fine. As for the new shoes I'd recommend buying some some zinc oxide or althelic tape, that way if they cause you blisters you can just create a false heel and carry on without the pain.
