I smell BS . . .
ok
I smell BS . . .
ok
I'll have my block tomorrow![]()
You sure about that?
Different card I know but my 980Ti EK backplate got red hot, hot enough it was uncomfortable to touch. Definitely hotter than 40c more like double that easy!
Can't say I share your confidence with this one. . .
)EK backplate is more for aesthetics. Most will hinder temps. Always find it better to either use active airflow or not bother. A full cover block is sufficient for VRM cooling. The Titan X is like all other reference designs since 780Ti, in that the board supplied by Flextronics limits voltage at resistor level to 1.25v. You're not able to push it enough to test tolerances, and performance should be relatively unaffected.
I got the 14W ones because I didn't fancy spending the extra for 17W... 14W will be more than good enough and a big improvement over the standard ones.
I got mine from the rainforest... but there is another supplier of watercooling parts in the UK who are a competitor of OcUK who sell them.
You haven't configured your trust settings so I can't email you either![]()
Did you put the nvidia backplate back on mustrum or just left it off?
I just left it off. I might put the EK one on at some point but i think i might just not be bothered. Optics used to interest me but nowadays I am only looking for maximum performance. Putting that piece of plastic (original backplate) serves no purpose.
Didnt realise the nivida backplate was plastic, had assumed since they had put thermal pads on the back of the card that it was actually metal
Any guide to the shunt mod please or could you highlight in your pics which ones you do please?
Also with the liquid ultra, does that "dry" and set? I thought it staying liquid until it got heated up?
