Hehehe...
A lot of the parts arrived today... unfortunately the 480 rad was severely damaged. Thankfully OcUK are advance-shipping me a new one. The UV cathodes for the reservoirs were also both shattered internally, so they are being replaced and some numpty in the warehouse managed to send me 16/10 flex tubing instead of 13/10 flex... argh... oh well, still managed to get it leak free as it's a tight fit and cable tied haha.
I only built it as a bit of a bodge to test bending hard tubing.
For a first try, I'm quite happy with it... I made a mistake or two but was able to sort it well. It's not perfect... I'll spend more time on the full thing to get it right as I could have made some simple adjustments to tube length to get it right but didn't need to for the test build.
Loop is CPU-only at the moment with a single Hardware Labs Black Ice SR2 Xtreme+ with 4x 140mm ML Corsair fans in push pull and I am already very impressed with this radiator alone.
The 560 and 280 for the basement are black ice nemesis gtx which are supposed to have even better cooling capacity... this is going to be a very quiet very fast system
I'm glad I swapped the 420 rad to a 280 for the front as a 420 this width would have interfered with a top 480 and I think a top 480 with 280 will look better than a top 360 with front 420.
I've set up a quiet fan profile at the moment that only ramps up above 30% fan speed and 50% pump speed at 60C.
At idle, the CPU sits at 23-24C and under full load it just peeps over the speed-up profile... so sits at a pretty even 60C under extended aida64 testing.
That's with a 4.2GHz overclock... so I'm easily going to be able to use 4.4GHz 24/7... possibly 4.5 or 4.6... I know I can achieve a bootable 4.6GHz - but don't know if I can get it stable. 4.5GHz is bench-stable, but ran rather hot with the Corsair AIO cooler.
The upgrade from Corsair AIO to this relatively small loop (rad wise, the same size - only a bit thicker) is MASSIVE.
Also looks quite nice... I'm happy with the colour combo and the res mounted UV cathodes are really going to make it sparkle
I want to use one of the reservoirs as top entry though... so I need to get one of those extension tubes as I'm getting quite the cyclone in there on a higher pump speed. Plus the trickle is marginally annoying - although not unpleasant.
Please excuse the poor quality phone pics... I'll take proper ones when the system is fully built.
IMG_0322 by
CosmicLogos, on Flickr
IMG_0316 by
IMG_0311 by
