**Unofficial Tyre Thread**
Man of Honour
17 Oct 2002
Would it be OK to get XL rated tyres for the stiffer sidewall, in an attempt to reduce body roll from the tyres without having to change my wheels, or is that a stupid idea?
It's going to make no difference. This is not what XL tyres are about.
Man of Honour
17 Oct 2002
I've often ended up swapping between XL and non XL for various reasons (availability normally) and never noticed any difference in ride or handling.
mjt
mjt
31 Aug 2007
Do you increase tyre pressures for the XL?
For some reason, my door sill lists the tyre dimensions I have for non-XL and for M+S, which is a bit annoying :p
22 Jul 2006
Looking at changing tyres on the wifes Qashqai ready for the winter, I have been recommended the following:
Michelin Cross Climate SUV XL
Anyone any experience in these?
22 Jul 2006
Also at what level is KUMHO tyres? Same as Linglongs?
e: another question...is there any online calculators to see if you can put different size tyres on without affecting rolling distance?
Current ones are 215/55/18, seem only a handful of tyre options.
Don
19 May 2012
Spalding, Lincolnshire
Kumho are decent enough - not necessarily a "top tier" manufacturer, but certainly a decent midrange option - much better than linglongs etc.
What car is this for (and do you need XL rated?) - Blackcircles is coming up with SUV type tyres.
22 Jul 2006
Thanks for the replies.
Car is a 62 plate 1.5dci Qashqai.
A friend is quoting me on the Michelin, however a seller on eBay is selling 4 of the KUMHO winter tyres for £359.
Wife is in the community and covering North Yorkshire so will be travelling up into the Dales, Hawes, Reeth and beyond so need some decent tyres for over the winter.
18 Oct 2012
Whats with the random pricing for thres these days?
Swapped out the 19's to 17's for a road trip, low and behold i have a nail embedded through one, so theres my excuse to get rid of the runflats
But how come michelin pricing follows this logic:
225/45/r19 y- £226
255/35/r19 y- £136
How the hell is the smaller tyre more expensive!?
Don
19 May 2012
I assume it's an NTEC or Tekna spec with those size wheels?
I assume you mean http://www.ebay.co.uk/itm/17-WINTER...ashqai&hash=item210c376fda:g:OSUAAOSwxp9W89FF
In which case, yes switching to 17" (or there are even OEM 16" wheels) is a good idea, as there is more choice (and therefore consequently also cheaper).
You can then run the smaller wheels/winter tyres for 3-4 months of the year, and buy some premium "summer" tyres for the 18" e.g. Michelin Premacy 3's are probably the best choice in that size @ £133/each.
Less common size I imagine.
26 Apr 2003
West Midlands
I am after 4 new tyres and when searching it seems most either have 'BMW Fitment', 'Audi Fitment' or 'Merc Fitment'. Does this just mean they are for those cars specifically or that it's just an OEM fitment?
