That looks good! Tom send me a link on FB please.
http://www.aliexpress.com/item/Univ...2707377435.html?spm=2114.13010608.0.54.SpA5Tr It does come with a baffle which looks like it'll really kill the sound but that came out as soon as I got it out of the box so I can't comment on exactly how much.
Copper grease is designed to stop things seizing, not for lubricating moving parts, your wheel bearings move along the axle, and you wont want copper grease in those, just use normal grease.
Replaced all the headlight bulbs.
Osram Nightbreaker low and high
Osram Cool Blue Intense side/position
They're all the same colour temperature which is between 4000k and 4500k which is nice and white, not the blue side or the yellow side, just a nice white. So much brighter than OEM. Why do they insist putting **** bulbs in at the factory. I know things are down to cost, but we're talking £20..
Off to get some petrol from the station down the road but I feel I may be a while
Will update with how good/crap it sounds when I'm back.
$26..what is it made of, imitation cardboard stainless steel?![]()
What QS did you go for Chris? I've got my eye on the shiftpower syncrotech quickshifter for a Tuono.
http://www.shiftpower.co.uk/index.php?page=prd_syncro
Well they are finally on,
Chris
Oh my, they look lovely.
Did your bike have cast magnesium wheels before? if so i'd be interested to hear if you can feel the difference.
Ahh, thought you might have done that, I doubt I'll be fitting a power commander at any point so need a standalone one
There's a nice Tuono black dream just come up on ebay for a decent price, good nick and low milaege too...
It's in ****ing Belfast.![]()
Flights out there are £10 one way from Gatwick but it'd be a stopover on the way back due to either a short ferry and long 8 hour ride, or long ferry and shorter 5-6 hour ride.
There'll be a huge weight difference, correct me if I'm wrong chris but his bike had the standard RSV cast alloy wheels, 4.9kg and 7.5kg vs BST carbons (from rsvr.net, might be out of date) at 2.4kg and 3.8kg. Over 6kg weight saving
The forged alloy wheels on the factory models are 3.4kg and 5kg, so lighter than the cast wheels but nowhere near the BST's.
