Codes are tied to accounts they claim..
Doh ok mate, thank you very much
Smrtka; B)Its part of most of games said:One of the things I try and do is get a beacon placed in a sneaky unseen place too and protect that. You can literally control a game of rush by having your squad keep pouring through and back rageing the hell out of the other team!
As a avid sniper in most games I played one round before work and I have to say the sniping is OP, Mainly if you have a quick reactions you can win against assault rifle close range and so on. I was not able to get the feel for the bullet drop from that quick game but I was hitting HS left right.
to your frustration
A) Playing sniper to me show a skill of marksmanship. Its hard to hit HS on a running guy over a distance. Lot of hate comes from people who are not able to do so and consider snipers "useless" or annoying. Now i do understand the anger for a guy who lies on the edge of a map and does nothing...thats quite angering even for me but If I play objectives as sniper and then keep distance to protect the objective or take different route to flak/suppress enemies thats snipers role well done....so yes I do enjoy sniper gameplay....and its satisfying hitting them dank headshots then spray and pray with smg or lmg.....
B)Its part of most of games, and was the same in BF 4 and 3 if you get rekt by a sniper after running for 3 minutes he is good, doing his job protecting the objective and you will learn to push with a vehicle or your teammates...
That said I too do hope the BF1 will not be sniper fest as 90% of so called snipers do not take objectives and just hide in rocks far away
What FOVs are people using?
Closest i can get to 4K on 1440p is using 71% which gives 3848x2164
It was a robust defense but in your own admission 90% of people who snipe just do it for a great Kill/death ratio stat and aren't playing the objective or even helping.
If the game is making those people even more powerful then it's not right.
Particularly now that they have changed the way scores work so that kills won't run down your tickets. Those 90 percenters won't even be helping their team in any way really.
One thing I have noticed so far, I havent been revived once, in about 10 rounds. Im not sure that people even know how to revive on this yet.
I'm really liking it, but again apart from the UI. Looks like it's just taken from XBox. What's wrong with Battlelog?
90 and 75
That and with kills/deaths not counting towards tickets, people don't see much point reviving now, unless they have changed it since alpha were reviving will remove/add 1 ticket...
how you turn off the green fps meter. i havent got anything running so must be in game![]()
Same just tested it.
At 71% Scale I get: 3848 X 2164
At 70% Scale I get: 3815 X 2145
4K iirc is 3840 X 2160
