- 10 Nov 2006
- Lincolnshire
Problem is, people are usually out for themselves or just not thinking.
Sum's up what most of the moans about this game are about.
As for behemoths, since when did battlefront have behemoths?![]()
I'm referring to the AT-ATs
The anti tank rifle is by far the best pick up. When you first spawn make your way to E, pick up the rifle, go prone and attack all incoming jeeps. Blew up a jeep and light tank as soon as I picked up the rifle last night, got 5 kills in the first minute of the match.![]()
They're not behemoths though, they don't even function in the same way. And unless the at-at head was pointed in the right direction due to it barely being able to turn a lot of the time they didn't have any impact on the game.
The only time the AT-AT is useless is when it is turning to face the new set of points and on endor. It has a massive impact on the game on most maps especially Hoth. The empire side might not win a lot of the time but that is more down to players just not pushing the objectives.
Plus, once the planes have good unlocks, I can see them dominating the ground quite a bit i.e. the rocket podsOkay if the comments here are "thoughtless nonsense." What does "Flow better" actually mean? Don't just pluck up phrases out of thin air without explaining what you mean & the point you are trying to put across otherwise you are just giving an example of thoughtless nonsense yourself.
I have to say, this game for me doesn't feel right, for some reason it feels exactly like hardline. My opinion. I play on a server go 27 to 3 on foot and the next round go 7 to 7 same play style same server ? This happens often and frustrates me a bit. Things i like is the sounds of the weapons...
Horse riding is well bugged, I use the sword like 5 meter away from the infantry and get the kill. There is no skill in getting kills on the horse, the moment you are in 5m radius of the player and use the sword you will get the kill..which is odd
The sniping the bullet drop is 0 up until certain distance and then it is MASSIVE... Point blank shots with the most powerful sniper are 70-93 dmg... so there goes no scopes, so doesn't matter if you miss your shot or hit SMG/LMG will kill you unless you can pull pistol faster or enemy is blind...
I will play the beta, and I will not buy this unless its 25 quid, but by that time it will die like HL and battlefront...
Planes doesn't let me assign my joystick which for me is a big no no. People will tell me to use xbox/ps controller or mouse but I got used to joystick and I HAVE THE OPTION in the menu it just doesn't let me setup or control the planes... It may be just alpha bugs tho...
I was hoping for a reskin, honestly! I was not expecting a new game, but if they would resking BF 4 or 3 rather then hardline. I would not mind paying for that as i got like 1200+ hours on bf4/3 and if they would be lazy and literally just change skins/weapons (maps and vehicles to match ww1 but based on bf4/3) it would be good enough. This was not the case and thats disappointing.
It means the battle seems to flow from point to point in a more reliable fashion. It means the front tends to move together (especially in the centre B>C+D>F area) rather than completely haphazardly.
A lot of those can be applied to pretty much any other battlefield game, going good in one round and not the next is just gaming in general, good rounds mixed with bad rounds. As for flight mechanics, battlefield has never had even vaguely realistic flight mechanics, you just have to look at what attack helicopters were capable of doing back in BF2 to know this. As for behemoths, since when did battlefront have behemoths?So far ive seen a few "heroes" being used and they were dispatched pretty quickly, their influence over the fight has been wildly exaggerated due to people playing battlefront and seeing their impact in that game. There's no darth vader, boba fett or luke to contend with so its not even remotely on that level.
