I'm only ~318. Hope I don't get rekt
Oryx is 320 light on Hard. The fights before that are lower. War priest is 290 I think with golgoroth 310.
You'll be fine.
Is HM easier now with higher light? Don't wanna stuck on the doofus for hours![]()
How does the new drop system work then...if I'm going in at 323 light, will drops be :
323-327
or
323-335?
As above it is easier....sort of. Everything is easy up to the Sisters and Oryx as DPS is no longer a problem. However the mechanics of the fight are still an issue as if 1 person goes down it is hard to recover. So you still need a perfect run, it is just easier to get the perfect run.
I think the first time most of us did HM we were only around 312-314 or thereabouts so you should be fine. Also the earlier boss fights are lower and with a couple of good drops should see you over 320 ready for Oryx. DPS shouldn't be a problem but thinking a head, if you take the second plate then you would always have help from first or third plate to take down your Ogre.
I think it is up to 5 above your current level so you should see drops 323-327.
Drops are up to +5 above your current light level![]()
Hard mode is fairly easy these days guys if you're doing the 16 orb strategy.
For those that don't know the drill you need 1 hunter with tether and 1 defender titan with armour of light, then:
1. Hunter tethers adds at the start to generate orbs.
2. 3 people and the runner go to their platforms while the titan and 1 other remain in the middle.
3. The runner starts his run while the titan pops a bubble and the two guys in the middle take out the ogres plus the 4th knight. The only job of the guys on the platforms is to DPS their ogre then shoot their knight (and not die). Platform guys go to the middle once the runner tells them he has the relic.
4. Runner grabs the vessel's shield and everyone kills the mofo.
5. Stagger Oryx.
6. Kill any adds that can shoot at you but leave the thrall alive.
7. When it says Oryx has regained his mojo at the bottom of the screen the hunter tethers the adds to make orbs for the titan.
8. Everyone gets sucked into the other area to kill Oryx's shade while anyone outside prevents adds from getting in.
9. Repeat x3 but on the 4th run detonate all 16 orbs after staggering Oryx.
10. Run up to him and shoot him into space.
11. Pick up all the 334 loot and modering shards.
Put me down as a sub, I should be able to do Thursday
1. Middgen
2. Venom
3. OweO ?
4. +1
5. Moe
6. Greboth
Sub. TehBluebear
Gonna be infusing my NM gear as usual
Will be on from around 6 UK time, for Nightfalls/CoE whenever people are about, and then raid when Greboth gets on.
Got a couple of crucible quests to do for triumphs too, think I need one more win in a fireteam...
If you already have good rolls on your <320 gear I would just infuse that to max instead of trying to build an entire new set of armour with the right perks.
Should be on around 6pm too, up for a nightfall and CoE. I'm just missing return to the reef and challenge of elders for the triumphs, but can probs help you out with PvP
