Ministry for silly looking cases award goes to...
6 Oct 2007
North West
https://www.techpowerup.com/225518/corsair-announces-the-carbide-air-740-chassis#comments
It is optimised for airflow over aesthetics though doesn't look too bad to me - shame it seems to have some of the negatives as the 540 with regard to the internal drive cages, etc. though :S (With the rear position like that would have been nice if you could slide SSDs in and out without having to open the whole thing up).
Ive seen worse tbh, and airflow should be good as it was in the 540. Nice unobstructred path from the front.
Only the top really that doesn't work for me - but I could live with that for good cooling performance. I think I'd probably buy another 540 over it though as I like the slightly meaner look.
I'm not gonna lie I'm a Corsair fanboy but that is just fugly.
I hope this doesn't replace the 540 as it's bigger than it and IMO it doesn't look anywhere near as clean, Minimalistic or compact.
I notice the additional cut-out under the USB ports and power switch - would that be for channelling extra connections to the front such as when connecting up VR gear ? Review doesn't seem to talk about that.
Looks are definitely marmite. I'd stick with my 540 for several reasons:
- Those front fins are dust traps.
- Don't like the hinged side, you need more space to open it up rather than the existing couple of thumbscrews and slide the panel back.
- No open drive bay. I'm old school and want my blu-ray drive in the case instead of external.
I think it looks OK to be honest. Certainly not amazing to look at, but it doesn't make me wretch.
Yeah I've seen far far worse - I actually consider it largely "inoffensive" its just not very interesting rather than bad though the top kind of sits a bit wrong.
Still hoping to see something like a 540 revision 2 that makes a bit better use of the case's potential the case is close to perfect for me just would be nice with some tweaks.
