I can't tell a lot from it i'm afraid. The ones on the same sides seem to be fairly even though. Which is good. Maybe they could be a bit higher. I don't think they're massively low
Dropped them in to the LBS yesterday evening and they checked the tension whilst I was there. The RDS was right in the middle of range and the guideline given for the RNDS is about 1/3rd of that for the DS. Running as close to perfectly true as possible.
They're going to increase the tension today towards the upper end of the range and I'll see how that goes. The rub had improved somewhat but was still apparent even when in the saddle with weight off centre. At 78kg with power output not out of the ordinary it seems a bit amiss considering since May they've been fine though have taken a fair few knocks lately
