Caporegime
- 18 Oct 2002
Looking like a good driverset so far
Noticed 16.9.1 also showing as WHQL under Dxdiag16.9.1 showing incredible improvements in DX11 what a beast driver!!! this is good stuff. I had trouble with the dota 2 crossfire profile but I think it was something I did specific. BO3 / new NFS running exceptional now !! huge FPS increase!!
still on 16.6.2Although it looks like the main fix is to use Clockblocker, is this recommended? Seems a bit odd that you have to install a non amd program to get it to work properly
application profiles
Application profiles, Xfire CAPs back ?
I'm no longer having the clock problem, It was fixed within a few weeks of Crimson starting, I run my Fury with the power efficiency setting ON and it sits at it's 1040 clock consistently.
do you see any performance issues in games?
I think it's just these?
I've not had the 100% GPU load with these yet, but if i dont up the power limit my core clock doesnt stay maxed out. Add 10% and it maxes in 3DMark, without the extra power its at around 1250 core instead of 1306 (can see the difference in 3DMark scores too), and in games my load is up and down like a yoyo, 100% then down to even 0% and anything and everything inbetween. Surely this isnt right, my 7950 never did this.
Had this problem on 16.8.1, 16.8.3 and now these 16.9.1 drivers.
Power Efficiency and Compatibility Mode are disabled.
Whats going on here guys?
