Caporegime
- 8 Jan 2004
- Rutland
Don't feed the troll
Quick question - would I benefit from a second Sonos 1?
FINALLY!!!! I'M SO HAPPY ABOUT THIS![]()
Sonos is finally opening its great speakers to Spotify's app
http://www.theverge.com/circuitbreaker/2016/8/30/12709368/sonos-spotify-app-support-announced
Finally i'll be able to use the spotify app to cast to my sonos system without relying on the rubbish sonos inbuilt spotify tab (which is really crud and doesn't even let you search / list your music by artists). I've tried a few 'hacks' to get around this but none of them seem to work properly and don't satisfy me at all.
I seriously think i'd have ended up selling my sonos system were it not for reading that link![]()
Their connect box is eye-wateringly expensive. I can't see why it needs to be such a large premium over a speaker that presumably contains the same components (minus the line in), plus a speaker.
My ideal Sonos setup would be to simply have it as an input to a home theatre system, and sitting on the record out of the receiver in case you want to keep listening to a sports event while you go and take a dump or whatever. The Playbar and sub money could go a long way on other kit. I see the value in the self-contained speakers though.
I don't either....I got mine used for around £200 and even then it was a bit pricey. It does contain a variety of outputs plus the ethernet ports though, and of course runs the software like the others. I expect they apportion most value to the software which is why they keep all the hardware prices high....Their connect box is eye-wateringly expensive. I can't see why it needs to be such a large premium over a speaker that presumably contains the same components (minus the line in), plus a speaker.
With this kind of system the quality of the software and reliability of the connectivity is at least as important as the ultimate sound quality. I have little faith in the ability or desire for companies like Samsung and Denon to ensure that their software receives timely updates to support newer mobile device operating systems and streaming music services.
I'd be more worried the other way all the other companies can bow out of the multi room market as its not their core business, but Sonos can't, if they don't keep up they're done for.
Been burnt by Samsung already, bought into their NX camera system and they bailed out the market leaving me with an incomplete set of lenses and no decent upgrade path.
Sonos isn't cloud based is it? Even if Sonos went bust, you'd still be able to use the app to control the speakers. Surely?
Sonos probably won't every use Bluetooth due to the inherent SQ issues with it.
Had my Play 5 in a field this weekend at JAE, it did very well for its size although I'm convinced that the volume via line in isn't as high as it is via wireless.
Did you change the gain in the settings? Let's you tweak the volume a fair bit.
