Where to buy....
3 Jun 2012
Hey.
Started new teacher training.
I have never had to wear "office" clothes and I'm struggling with trousers.
I'm after the following:
34" waist
Some kind if elastic on waistband (we all blob out when sitting)
Slim fit (no wafty legs)
Durable.
I'm struggling to find the above, I have been to lots of shops and tried various on but none seem to suit.
It's really annoying because I'm really uncomfortable all day and I'm being forced to wear this attire.
Any suggestions where I can locate something that fits ?
M&S active waist easy care trousers. Not a super slim fit buy I don't think you are going to find a slim fit with the other features you want.
/Salsa
as above M & S all the way, cant fault their stuff good wearing reasonably priced and the active waist range is just what your after
/Salsa
Exactly these - the active waist ones are the ones to get.
Having bought loads of trousers for work over the last 10 years, you get what you pay for, and the M & S ones are worth it over supermarket or other cheaper trousers.
Proper mens outfitters, a good one will measure, listen to what you want style wise and pick you out something good quality that'll last. Itll be pricey but the great thing about quality is you can buy it. If your gonna spend 8 hours a day wearing something might as well be comfy.
Your teaching, so fashion isnt an issue, after all no matter what you wear the kids wont think your cool.
