Thanks for you kind wordsHopefully you are better with numbers than you are with letters. I really can't understand what you are trying to say.
I'm trying to say the Beeb is not clean the numbers they release to you all are not correct they look clean afterworld the wages are not correct ?after expenses , and tax paid .
What I am saying is they do not. Tell you the truth
Okay my guess. You worked briefly for the BBC and were sacked as, well a read of your appalling ill thought out posts would give a good idea on that that. You now spend your spare time sharing your nonsense on various random forums.
The only plus point is I doubt you will be around for long before you find the next forum to share your 'knowledge' with.
I still work for the scum bags unfortunatly , just so I can tell you how masodanistic they are
If you ban the domain name it doesn't matter what the ip address is, any request for the domain gets stopped.
However that doesn't help if someone knows the ip address of the bbc sites and tries using that as it bypasses the domain name look up.
Brilliant comment thanks w.
