Nexus 5 2015 refresh
Nougat is out - downloading to my 6P now. Apparently none of the leaked new features are present though :mad: No new nav bar, no fingerprint scanner gesture, no double tap to wake, new blue setting menu...
All that being saved for the new Nexus apparently, I think the older Nexus devices will probably get those features with an update at some point.
Updated my 5X yesterday, it's been running a bit sluggish for a couple of weeks, kept putting off doing a format.
After installing Android 7, I had an issue where Google Play Services kept crashing, so I formatted the phone.
Faster than ever now, seems much snappier than when I first had it :)
Loving the new small display size option..
Settings>Display
Font size - Small
Display size - Small
Makes everything tiny :)
Settings>Display
Font size - Small
Have you set your animation speeds to 0.5 in developers options? Prepare to be blown away if not.
So I have a rooted latest android 6 on my 5x how do I go about getting 7 on? Can I just flash the ota using flash fire? Or will I lose root?
Nougat is running really nice on the 5x, seems to have sorted the slow down/lags I noticed every now and then over the last few weeks. Split screen mode works great too.
Only issue is battery seems to drain quicker over night. Seen a few people mentioning this.
Yup, I've noticed that issue.
I think before the update, I only lost roughly 2% overnight. Now it is something like 15%
Anyone know why I'm not on the new update ?
5X user here on EE.
Are they making me wait
No idea, I'm on T-mobile and got mine last week I think. Just luck of the draw I guess. I got this months security update for 7.0 yesterday too.
Looks like my doze issue is back. 19% gone overnight.
I've not yet got the update either, nor is this month's security update visible to me.
Guess we must be in one of the last batches DJMK4.
I enrolled in the beta, got the update then un-enrolled, phone didn't reset.
Update: Done a reboot (First reboot since the OTA update was done) last night, Used the phone until it was 70%, Left it for 8hrs and only lost 1%.
Mine seems to have somewhat sorted itself out...
I just got nougat and my battery lasts half of the time.....this is a joke.
Overnight the phone lost 25% when it used to lost 5%
Battery usage:
Screen 7%
Mobile standby 6%
Android OS 4%
Android system 3%
Battery usage:
Screen 7%
Mobile standby 6%
Android OS 4%
Android system 3%
Have you done a fresh install?
