- 13 Nov 2007
Anyone got a link to all the benchmark results?
So I'm 99% certain I'm going to be replacing my 970 with a 1070 this week. Having a look through the ones on sale I'm struggling to work out why I would go for anything other than the KFA2 EX OC? It's only £20 more than the very cheapest, seems to have a good cooler, and a back plate, yet has clock speeds almost as high as some of the £420 cards.
https://www.overclockers.co.uk/kfa2...ddr5-pci-express-graphics-card-gx-091-kf.html
Is there something I'm missing as to why I shouldn't go for this one?
http://forums.overclockers.co.uk/showpost.php?p=28330031&postcount=4111
Looks like my Gaming X still the top 1070 score
Lets see some more results as I don't think mine is the best clocker out there plus its not even under water![]()
Don't think it has anything to do with the brand of the card. You sir won the memory lottery there. My card can easily match your core clock for benching. My memory however can only do 2300 stable, maybe a bit more for benching though. But 2500 is very good. Essentially that is GDDR5X default clocks for 1080
I look forward to Vega, HBM2 will hopefully be awesome memory.
Yes my memory clocks very well, maxed out the slider in Afterburner. Its not game stable at those clocks but will pass a few benches with 100% fan speed without artifacting. I game at +110/+600 and its rock solid at all the games I've tried.
I think there are others with better core speeds though![]()
How is it that your memory is near the 2000MHz region but Precision X shows mine sitting around 4000MHz? I'm obviously reading something wrong here.
Quick question, what's the better card between the MSI Gaming X and the Gigabyte G1? From what I've been reading, the MSI appears to have the better cooling and is quieter.
I haven't had an MSI 1070 but i've had their twin frozr 660 and 970 and can say their cooling is the best i've seen on any card. My 970 OC'd to max would sit around 66c~ under full load with custom fan curve (so high fan speed) yet it was dead silent, they use some very good fans.
Whats the going rate for a 2nd hand 970 atm, £120??
