AMD fans where not saying that with the 5970's when the GTX 480 got released, they where quite happy (and rightly so) to rip nvidia a new on on the heat and power of that thing.
but then the tables turned with the 290/390 its not an issue anymore.
Power and heat with the 290/390 has always been an issue, don't make out that that people said otherwise, the 290 got slammed everywhere the 390 came custom cooled from day one and seeing as most know that the 390 is a tweaked 290 moaning about the power and heat had already run its course with the 290.
The 5970 was a dual GPU card that use less power than the 480.
It was never an issue for me, i had a 290 for 2 years, it ran cool and quiet.
Like everything else AMD it was vastly over blown by Nvidia fanbois.
AMD Vega 20 will use Glo Flo 7nm? I highly doubt that as they said they only just decided to skip 10nm and go to 7. Are Global foundries even producing 7nm wafers yet?
Maybe true for Navi but doubtful for vega.
The stock cooler on the 290 was a disaster and yes the rest a bit overblown.
Interesting rumour, the first thing to remember is that this is supposedly from the server roadmap, so the numbers are for the server variants not the desktop cards.
what does this tell us, well it would be.
4096 stream processors (effectively two rx470's)
24TF FP16 half precision (hmm not too sure about this seeing as the 470 only does 3.7GF full precision FP16 so about 7.2 half precision FP16)
16GB HBM2 (quite possible on a server card)
512 Gbps memory bandwidth ( seems quite low)
225W TDP
By comparison
NVidia P100 (equivalent HBM2 card)
3584 Cuda cores (not a full chip, so maybe the AMD Vega 10 isn't either seeing as it is only 2x470)
21.2TF FP16 half precision (or 9.3GF full precision FP16 so about 18.6 half precision FP16 for the non mezzanine card)
16GB HBM2
720 Gbps memory bandwidth
300W TDP or 250W for the non mezzanine card
As for a desktop card, performance wise it would be about two 470's. Make of that lot what you will.
Disclaimer: all info taken from various sources around the web and I now have a massive headache, so it may all be complete baloney.
470 is what? slightly slower than a 480? Dual 480 is a bit better than a 1080 where supported and in AMD favoured titles? so you could say that the small vega is roughly around 1080 performance? this is all ifs and buts obviously...
a lot comes down to price, if Small Vega is actually in reality trading blows with 1080 it needs to be cheaper, but i cant see it as i am sure HBM2 will come at a premium.
You are assuming Vega is Polaris which it appears not to be. If it's the server card then it's probably clocked a good bit lower so possibly higher clocks and tdp on a gaming card with higher bandwidth.
Hmm isn't Vega 10 the bigger of the two Vega chips?
Yup, could be.
Also there a lot of assumptions, guesses and estimations, in this sort of rumour.![]()
The RX 470 has 5 TFlops single-precision, so 10 for two of them.
Which mean's at 12 TFlops single-precision Vega is clocked 20% higher than the RX 470. 1450Mhz.
Hmm yes your right, looking at the Techpowerup database it lists 4.94 Floating point where this AMD GPU wiki only list 3.793 single precision.
We would have to assume the Techpowerup database is more accurate, seeing as it is more in line with what AMD themselves list.
and good business practice to sell chips that aren't 100% justSteam has not surveyed me for 3 years, so my 3x290s have never been registered and at this rate they never will as i would have moved on from them before i'm asked again.
