- 19 Feb 2007
- Northampton
Yeah and he's running a CPU far superior to mine..
I wouldn't say far superior, it has 2 more cores and slightly increased IPC.
Can't seem to just to a loop for the titan xs for under 300. Not that I can find.
Greebo
Did you do any photo's of your finished rig?
Best I managed was a 12.5mm insert from eBay which was still too slack.
might have to buy some rubber mounts and do some sound proofing on them. I can even hear the faintest of coil whine from the Titan on game menus when the fps is above 500fps.Considering getting a Titan Pascal is watercooling one that much of a boost?
Yes
It gives constant clockspeeds around 2100 on the core when overclocked on stock volts.
And how much of a boost ingame does that give over a clock of around 1950? Probably 2 or 3 fps at best. Barely worth the effort.
Working on that logic would I be better off just using my 1080 instead as that is 2 or 3 fps slower than the Pascal Titan. But wait I could use my 1070 as that is only 2 or 3 fps slower than my 1080, but then I could get out one of my 1060s as that is only 2 or 3 fps slower than the 1070, oh heck I think I will just use integrated graphics and leave the 1060 on the subs bench.![]()
