Thanks for the reply! It seems weird though that one controller is still working and on the same driver?Seeing as those a 3rd party USB3 controllers (renesas), try getting drivers direct from them. Given it says Microsoft in brackets at the end means you're using the drivers built in to windows which are usually substandard compared to proper manufacturer ones.
I can't appear to find any Windows 10 drivers for Renesas
