- 23 Oct 2013
I had a 6mps a couple years ago - took a while to find one as most of the ones close to me were in a pretty poor state. I had it for about a year and it was a money pit. When it worked, it was ace, sub 6 sec 0-60 and nice awd slides in the wet - basically it's a sleeper scooby which goes under the radar and somehow has amazingly cheap insurance for the power.
The car itself is good and I got the impression that when new it would have been ace, but at 7 years old, it was past its best.
There's so few of them about, especially decent examples, that I'd imagine someone on the owners club to know the history of anything for sale.
problems or issues to think about:
1) Timing chain stretches and needs changing about every 70k miles (there's a MPS "specialist" garage up in windermere, and speaking with him, he's even suggest they could be worth changing every 50k).
2) The rods are like chocolate and most tuners seem to have had issues with cars popping, so 90% of the owners group use a guy called Justin (or J-tune) as his tunes seem far safer than others - so, if it's been tuned elsewhere, then potentially walk away.
3) The rear diff mounts are also chocolate, so need upgrading if you plan to launch the car regularly.
4) the rear drive shafts are a slightly harder chocolate and seem to be the next thing to go once the rear diff mounts are sorted.
5) the mazda underseal/rust protection is awful, so expect the underneath to be a state by now.
6) the AWD system is temperamental and needs all 4 wheels to be the same (from memory, i think the manual even states that all 4 need to be the same model tyre) - if you find a car with different tyres (or front/back different) then it's probably not been looked after and the rear diff could be poorly. So, expect to fork out for a full set of 4 tyres anytime you need 1...
7) the bonnet has a air scoop built into its design - a small opening on the front lip which sends air to the top mounted intercooler. But, it's also a great water trap and the bonnets are prone to rust, so check that.
The common tuning route is with a Cobb Accesstuner - a great device, which has its own software to upload the tunes. Cobb chose to stop Joe Public having access to the software (and each copy is linked to the device's SN) so now you can't road tune with a Cobb & Justin
So, look at Versatune for the present preferred option.
i always remember that Top Gear episode when they put the MPS, VXR and ST220 together and despite the fact they all had similar power the VXR spanked the both of them easily and would also achieve 300bhp with a map.
Yes everyone uses a lad called justin (DJJUT) on the forum, he's mapped in excess of 300 mps's now iirc
