Don
- 20 Oct 2002
- Oxfordshire / Bucks
thanks
Now going to look for a polarised filter for it to remove the glare (it's not bad but want to see what it's like with one)
I bought mine directly from Thinkware, speedy enough delivery.
You need to find an ignition live, I find the overhead console is best as you can have a short cable run.
You can either find one from using an online diagram, or a volt meter.
Just check the wires for a 12v feed when the ignition is on, and then turn off the ignition and check the voltage is 0.
Is the camera actually 12v? Quite a few are 5v using a step down from 12v in the cig lighter. So you may need to use the circuit in the original ps to ensure it does not go pop!
You can just used a 12V hard wire kit. Piggyback off your fuse box using a fuse tap from a fuse that's live on ignition (which is what 99% of peeps seem to have done) and something something Bob's your uncle. You can ground from any existing grounding point on the car, usually brown wire is ground, but consult a diagram or owners forum to confirm for your specific car.
I have a hard wire kit unused and still in its packaging I can send if you do want to go that route. No charge.
What's their official UK site? There's so many "clone" sites it would appear.
But won't that be a 12V Feed which will kill the dashcam? Or is there a step down somewhere in the hardware kit?
