Always do. I never trust anything so always have at least two backups of important files etc.
right so you didn't almost lose the files then.
Hehe, well might aswel have it matching if I can, as I have spent a fair bit of money, changing my stuff from black to silver. Shame to ruin it now. My monitor was on the way out,, so I thought why not have a change of colour, I might have been bonkers but hey.
Im thinking to have the backup hdd box ontop of my pc at the back, as it will just miss the shelf.
Just got new case new H440 black mat, will be upgrading my graphic card soon. I have 3 noctua redux fans on top and 3 stock in front will be replacing them soon. Not sure if I will get noctua and commander mini with lights or maybe go with RGB 120mm fans so I can light up a case. Don't know yet as its hard to get silent fans that are RGB (noctua fan here).
I will be re-routing cables for now I need to get some extensions and make a whole in a shelve. Please give me some tips if you have so I can improve it further.
If your going to get any led fans don't bother putting them in the front as they will not do much for lighting as there's too much distance and stuff in the way, and as the H440 needs all the static pressure it can get to get air in the case I would put the Noctuas in the front as I did an put the led fans in the top and back.
I also highly recommend the NZXT Hue+ for led lighting.
Speakers are too high unless you have a massively long neck like a giraffe![]()
You cannot really see it in the pic, but they are tilting down quite a bit.
Just get rid of the poo wooden shelf and have the speakers either side of your monitor...
It's a corner desk...and I could have it looking ace in minutes...at the mo it looks poo.
How in the world can you stand to have a setup like this? its far too small and cramped, would drive me mad! lol
also i strongly suggest you move whatever that black box is behind the tower as its blocking the PSU exhaust
