sky window how big?
7 Sep 2008
hey I am getting an extension made 6m x 4m so 24 metres squared
I'm looking for a sky window like a lantern. - I think I want it to be quite big
I can budget 2-3K if required
what size shall I go for?
any general advice for such a project?
Flat roof ?
yes flat roof with fibre finish I hope.
just an idea but loads cheaper to get triple glazed flat units rather than a lantern
https://encrypted-tbn2.gstatic.com/images?q=tbn:ANd9GcSG2H6Kq-u97fId6yP8MK2vKyh692yERxG-hBw9gXd0u7Qa-dsOjg][/QUOTE]
But don't lanterns look so much better and have like less problems with rain water and moss sitting on them!?
My proposal is get a big window as it is a north west facing garden and super cold at the back of the house. Daylight would be very crucial
I'm thinking 1.5m X 2m or 1m x 2m but this is still open to debate
My extension is 4m x 7m and I put 3 x 1m x 1m Velux domes spaced equally in the roof. They let in a lot of light and make the room very bright. I'd make sure you add some form of blind to allow you to cut the light out when needed, such as people sleeping over or movie nights.
ah clever so like three sky windows instead of 1 big one!
I like it
Aye, here's a picture. I havent got any blinds yet, the velux one's are a few hundred quid if you want the electric remote control one's.
that looks lovely but would it bring more daylight than the one 2m x 1.5m lantern window I am proposing?
I think your windows would prob cost more than 2-2.5k?
What is your total build cost? If you want wow factor you need to invest significant percentages in key areas!
I'm looking at around £1000 per square metre which is £24,000 just for the build
I'd expect the other things to be up to £5,000 in total so like £29-30K
it is london mind you expensive around here :(
£1000 per square meter is pretty much dream territory in my experience, or are you building it yourself to a very standard finish?
Or have you already got a few quotes from builders for it?
I think you really need to get a handle on your costs/budget before worrying about the size of roof lights.
The 'going' rate of extensions nowadays are between £800 and £1300 per square meter in the London region. Everything is expensive here including labour!!! All quotes I got where in this region. The cheapest is not always the best
If I was building it myself do you think the building costs would be that high?
the only time I've seen extensions come in at 1000 a square meter were self builds, never seen any using a contractor come in at that - have seen many quoted around that figure and then when it's properly priced its no where near - have you got a full spec/foundation design etc in place or are you trusting contractors to put their finger in the air?
I've got all the designs and specifications including foundations so far.
where do u live? Are you from London or the south east?
